Canon NP7030F print quality issues
  • pcs
    • May 2009
    • 26
    The unit has approx 194K on the clock and is about 10 years old.
    The unit started out with toner at the top edge, bottom edge, from right edge to about 2 inches in, the left edge and some spattering toner on other areas of the page. There is also missing toner (very light print) near the center of the printed page. They said this all stared shortly after installing remanufactured toner. They have scents replaced that toner with OEM.
    Here is what I have done:
    Vacuumed out as much toner as I could see, removed the toner and vacuumed the toner area.
    Still the same.
    Replaced drum
    That has taken care of the right edge to about 2 inches in issue, the spattering seems to be gone and the other edges are better but still there. The missing toner (light print down the center) is still there.
    I am thinking it may be a bad developer
    Any other ideas?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Could be a transfer issue.
    You Vacuumed. Did you get shock?
    • teckat
      • 16083
      Worked on many NP"s -but what is a NP 7030
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        NP7130 was a table top,,, I Google'd NP7030, and saw a lot of South American references, like Chile & Argentina.
          • 22999
          pcs mentions developer... The NP-7130 is monocomponent. And every Canon NP-series machine is monocomponent.
          I don't recognize the NP-7030 model number. At present, just call me confused. =^..^=
          • SCREWTAPE
            East Coast Imaging
            • 3396
            NP7130
            Here's a shot.
            • teckat
              • 16083
              Originally posted by SCREWTAPE
              Here's a shot.
              looks like it belongs on the ANTIQUE ROAD SHOW
                • 22999
                If it is a NP-7130F, the first thing I'd say is get install OEM toner, make sure that the mag roller is clean (while it's empty), and do the exposures adjustment in the book. The aftermarket toner makes very poor copies.
                • Canuck
                  Tech Specialist
                  • 1713
                  Son of the NP6412....Crash the machine mid cycle on a sky-shot and check if the image is light on the drum. If not,move left. If it is light,move right to the developer. Pop the drum out and see that the dev cylinder is fully coated. But step one...give the optics a good cleaning. Check the shutters on the lamp carriage...techs like to tweak these to get rid of the dark area down the center of the copy that appears when the drum starts getting old.....wow...been a while since ive worked on one.
                  • pcs
                    • May 2009
                    • 26
                    Thanks for all of your input, it is a 7130 not a 7030 my bad.
                    Thanks again
                    • Canuck
                      Tech Specialist
                      • 1713
                      coming back to me now...on np7130 when you replace the drum you have to input the primary value,ip offset value and run the set-up routine. These are all accessible thru user mode. Turn off machine...hold down auto button,turn on. Move thru list until you find...i believe...U1,U6,U7...something like that....been a while.
