iR5000
  • waffu22
    • Jun 2009
    • 95
    iR5000
    When i used CST 4 (8.5 X 13),the paper jam at the upper right door. The vertical path roller is OK as well as the sensor. But when i used CST 3 same size of paper the machine works fine. No jamming.
    The jam code is 0323.
    Any ideas?
    Thanks.
  • charm5496
    • 2387
    a 0323 jam code is not listed anywhere in the book. One thing that might be happening is tray 4 on an IR-5000 is fixed for a certain size usually 11x17. Where tray 3 can be moved to fit other standard sizes and your 8.5x13 paper is close enough to legal where the machine is letting it run without any issues.
    If other paper is running fine from tray 4 I would just run it from tray 3 and be done with it. If you need to change the paper size for tray you have to go into service mode and adjust it there.
    copier>option>user>P-SZ-C4 and change it to 21 for legal.
      • 23009
      Is legal 8 1/2" x 14" close enough to avoid jamming? Does it display 8 1/2" x 13" or 8 1/2 x 14"? I had to address this issue on a Sharp AR-M455N but in reverse. It was jamming, sure, but the machine displayed 8 1/2" x 13", when legal paper was installed and auto-detected. I'm sure that it's different on the Canon, but on the Sharp there has a user modes setting to select either 13" or 14" auto-detection. On the Sharp one of the machine defaults had been changed on just that model. =^..^=
      • smiley
        • Aug 2008
        • 615
        try to replace the your separation roller you tires and the drive clucth of casset 4.
        there is no glory without sacrifice
        • waffu22
          • Jun 2009
          • 95
          Mostly in iR5000 tray 4 is for 11 X 17. But you can also adjust it for other size of paper. I done this in my other machines here in my area. Mostly i used tray 4 for 8.5 X 13 paper and it works fine.
          • waffu22
            • Jun 2009
            • 95
            It doesn't display as 8.5 X 13 when you look at in panel board. It display as FLSC.
              • 23009
              You have cassette 4 set for 24 FOOLSCAP (more precisely Foolscap Folio) which is 1/2 of 17 x 13 1/2, or 8 1/2" x 13 1/2".
              I believe the setting that you want is 35 FOLIO (more precisely Brazilian Folio or Oficio II) which is 8 1/2" x 13".
              Foolscap folio - Wikipedia, the free encyclopedia
