ir 6570 print quality
if not coronas/ if u now run 10 of those same copies & or prints and still have that same blank image area and it does not move/ the common denominator in this case has to be the LASER PATH, if it is only effecting the A3 paper width ,what is left left - can't be Drum Heater -voids would be on other sizes
if that void area moves just on A3- u may have to examine the drum surface again in that area for discoloration or staining
Last edited by teckat; 04-08-2010, 04:54 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I have seen alot of trail edge deletion issues on long paper from shot fuser rolls and bearings...analog Xeroxs were famous for it....it was a no brainer amongst Xerox techs.Comment
