canon ir 6800 cn error code
  • redzx
    • Mar 2010
    • 23
    hello guy.. i wanna to know what the mean of E000070-0102 error code??
    my machine is break down now..
    i'm appreciate all your help =)
  • copy_suhail
    • 88
    canon ir 6800cn error
    E070-0101/E070-0102/E070-0201/E070-0202/E070-0302 Error Code
    If the grounding spring found inside the intermediate transfer assembly becomes deformed, the resulting static noise can cause the ITB home position sensor to
    malfunction.
    The grounding spring may have become deformed when a part inside the intermediate transfer assembly was replaced.
    Field Remedy
    Check the following contacts of the grounding spring. If any of these contacts is deformed and, thus, the electrical conductivity is poor, correct the spring:
    1 contact with the end of the primary transfer upstream roller
    2 contact with the edge of the plate
    3 contact with a plate around the secondary transfer assembly
    4 contact with a plate around the secondary transfer assembly
    5 contact with the secondary upstream roller
    6 contact with the secondary transfer inside roller
    7 contact with the primary transfer downstream roller
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Pull out the ITB ass'y and check for damage.
      Check the belt. Are you a tech, if not call for service at
      you nearest Canon dealer.
      • anothertech
        • 1771
        Clean the white patches on the inside of the transfer belt.
        • redzx
          • Mar 2010
          • 23
          t hanks 4 all.. i alredy fix that problm.. =)
          • SCREWTAPE
            East Coast Imaging
            • 3396
            So what was it??
            • redzx
              • Mar 2010
              • 23
              i'm open all the part.. and service all the unit..
              transfer belt n film..
              • teckat
                • 16083
                set up a maintenance program on your machines/ prevents > most service headaches
                • charlzz_90
                  • Sep 2015
                  • 44
                  Re: canon ir 6800 cn error code
                  Sir, what u mean service the transfer belt and film? Which film you mean?
                  Sorry sir for troubling you.
