Canon IR3300 Heater Assy. problem
  • prakash_tumkur
    My Canon IR3300 has repeated heater assy. problem. Thermistor, film, filament all replaced 2-3 times. Machine brakes down with error code 00000-00000. When replaced it works only for a day or two and then breaks down. No other machine problem. I have noticed that if volume copies made then copier hangs with message "Processing" and then 00000-00000. Last time even pressure roller was also burnt. Please given any tips and permanent solution.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    You mention all the items being replaced,, are they being replaced as a unit, the fixing film assembly? Or are they being replaced one at a time. I would only be replacing the entire fixing film assembly for E000-E004 problems. Some people replace the films when there is a physical problem with them, but electrical problems,, replace the entire assembly...
    Otherwise you are down to the DC-Controller, or the Main Power Supply PCB.
    • vj200729
      print mate
      • 81
      i have also faced same problem .on using atta ceramicrod i got some what good result.and i now use to place it without applying any glu to fix and some fuser oil taken from xerox dc 12 machine applied on holders of film.you try .my no is 0
      9995112019
      • teckat
        • 16083
        9995112019
        • mrfixit51
          • Oct 2008
          • 1975
          Originally posted by teckat
          [ATTACH=CONFIG]4478[/ATTACH]
          I thought it was just me who did not understand the statement... ;-)
          • kuby
            • Oct 2007
            • 1396
            I love the BIG ? teckat
            LOL
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              And more confusion......
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Are replacing the part #
                FG6-5712-120 FIXING FILM ASSEMBLY, Item 34
