Canon 1025if
  • zoeenez
    • Aug 2025
    Canon 1025if
    I have a 2 part question!!
    First, I am attempting to setup fax forwarding on this unit to an email address, I have the forwarding itself setup but the email part is broken. I assume this is because my SMTP info is incorrectly setup...anyone know how to do this correctly?
    Second, does anyone know if there is a way to utilize the fax forwarding so that the fax is printed on the machine itself AND forwarded to the selected destination?
    Thanks so much!!
  • teckat
    • 16083
    Thanks so much!!
    the SMTP port settings on this device can be changed through the remote user interface (RUI.) This is done by typing the ip address of the copier in the url field of a web browser. Access the device's settings by logging in AdministratorMode, enter the password if the device's System Management is locked down and click OK.
    Login to the device's RUI in Administrator Mode.
    Click the Network link on the left pane,and click the Change... button to make changes to the TCP/IP protocol settings.
    Click [Network] and then [Change] to make setting modifications.
    Scroll down to the PORT Number Settings section of this page, and change the SMTP Sending port number configured in the SMTP server.
    Change the SMTP Port number to the desired value
    It should be noted that other port numbers can also be changed in this section. There is no other place in the device's service mode settings that this can be modified.
    Additional ports that can be changed through this page.
    After changes have been made, scroll to the top of the current page and click the OK button. The copier may have to be rebooted to put the new settings into effect.
    Click the OK button and reboot the device.
    To setup Fax Forwarding you need to connect through the RUI of the imageRUNNER. Select Additional Functions, then Forwarding Settings.
    You can send to folder via SMB or email since it uses an entry from the Address Book. Make sure to add this location to the Address Book first.
    • zoeenez
      I have got the forwarding turned on via the RUI, but it only works to forward to a folder, not to email (even though the email address is setup in the address book). Do you know how to setup any additional email functions that may be needed to make this work?
      Do you know if the machine can print a copy AND forward a copy?
      • teckat
        • 16083
        The Remote UI enables you to automatically forward
        received fax/I-fax documents to specified addresses. To
        use this function, you need to specify the forwarding
        settings in two ways, and depending on the settings the
        function will work differently:
        ● Forwarding conditions are set: the machine will forward
        only documents that meet specified conditions.
        ● Forwarding conditions are not set: the machine will
        forward all received documents.
        NOTE
        [Forwarding Settings] is displayed only when you are in the
        Administrator Mode.
        Forwarding Conditions:
        The settings here enable you to
        specify the forwarding conditions
        that the received documents must
        meet in order to be forwarded.
        The setting items differ depending
        on the type of the receiving mode:
        Forwarding Destination:
        Specify an address from the
        Address Book by clicking [Address
        Book] → select the desired address
        from the displayed list → click [OK].
        Forwarding Settings:
        If you are forwarding documents to
        an e-mail address or a file server,
        you can set their file format to [TIFF]
        or [PDF].
        If you select [Divide into Pages], you
        can forward files as divided pages.
        • teckat
          • 16083
          System monitor enables you to view the transmission and
          reception results, monitor the status of the copy, send,
          receive, report, and print jobs currently being processed.
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            you need to go to the e-mail settings and add 2 things, the SMTP server ip address (or name) and the e-mail account (eg, copier@gmail.com) and password (if required for your SMTP server). Then you can add address in the address book and in the drop down change the type to "e-mail".
            • zoeenez
              Oh my gosh...I can't believe with all the awesome advise I still cant get this thing working...I am attaching a picture of the email settings I have setup....the server names are correct but must be in the wrong spots...can anyone spot something I am doing incorrectly? The password does not appear after I save the changes, but I assume it is still there encrypted so that it is not visible...thank you so much. 4-23-2010 2-23-27 P&.jpg
              • teckat
                • 16083
                Oh my gosh...I can't believe with all the awesome advise I still cant get this thing working...I am attaching a picture of the email settings I have setup....the server names are correct but must be in the wrong spots...can anyone spot something I am doing incorrectly? The password does not appear after I save the changes, but I assume it is still there encrypted so that it is not visible...thank you so much. [ATTACH=CONFIG]4154[/ATTACH]
                do u have advanced manual
                • D_L_P
                  Self Employed
                  • Oct 2009
                  • 1196
                  You have SMTP authentication on, but it looks like you didn't put a password in. If your SMTP does not require authentication, turn that off and leave the password blank. If it does require authentication check the change password box and enter the correct password.
                  • zoeenez
                    I enter the password and once I push the 'save changes' button the field is darkened and the password disapears. I am deleting all the POP information as I only want the machine to send and not receive, maybe this will help, but no luck so far.
                    • teckat
                      • 16083
                      POP Authentication before Send= OFF
                      <OFF>: Does not use an SMTP server that requires POP before
                      SMTP.
                      <ON>: Uses an SMTP server that requires POP before SMTP
                      (method for authenticating users who have logged in the POP
                      server before sending e-mail).
                      SMTP Authentication=ON
                      If you use an SMTP server that does not require SMTP
                      authentication for sending e-mail, select <OFF>
                      I Don't see anything wrong ??
                      a tech sent me this/ i don't think it apply's to you/ if so there is a work around
                      If you connect the machine to a switching hub, it may not be able
                      to connect to a network even though your network settings are
                      set correctly.
                      This occurs because the spanning tree process performed
                      between switching hubs prevents them from communicating
                      with each other immediately after the machine connects to a
                      switching hub.
                      • D_L_P
                        Self Employed
                        • Oct 2009
                        • 1196
                        I just noticed your SMTP server ends with .net, I dont know if the 1025 is robust enough to support .net framework
                        Can you test it with a public SMTP server like SMTP.google.com? Just change the SMTP server to "smtp.google.com"
