Canon S750 inkjet printer
    • 23009
    Yeah, yeah, I know. It's my personal printer, and I would tell anybody else that it's not worth the labor cost.
    It stops mid-print, and blinks out a diagnostic sequence. (7) yellow flashes, (1) green flash, pause, then the same sequence again. If I power Off the paper will feed out and the rest of the print job will clear the queue.
    It's not a real high tech piece of equipment. There are a limited number of possibilities:
    print head home position,
    ink level detection,
    ink nozzle cleaning detection,
    paper feed.
    I'm not getting any useful information off the print monitor. It just says that the printer is not communicating and to press RESUME (which doesn't help). Nor does restarting the print job.
    Does anybody know what the diagnostic blinkage means? =^..^=
  • Ikon Princess
    • 126
    fixyourownprinter.com try this, more web junk or jewels?
      • 23009
      The model # isn't quite right, but Canon is really consistent about their codes, so I suspect that this is a jewel.
      I have to grant kudos to this "trigger". Again and again new idiots misread his posts, and he must repeatedly point out that their trying to fix a user code not a service code, or vice versa. I'll try not to be one of these idiots.
      For those that didn't look at the link, the (7) amber, (1) green, pause, means that the printhead is over temperature and requires replacement. I've got $40 worth of ink sitting here, so I guess I'll try to track down a printhead. Thanks Princess. =^..^=
      • teckat
        • 16083
        paper feed.
        Troubleshooting Error Indications
        1) Error indication when an error recoverable by the user occurs,
        the
        indicator lights green, then blinks orange repeatedly.
        Check the number of orange blinks and proceed to correct the error.
        2) Error indication when an error not resolvable by the user occurs
        The indicator toggles between orange and green repeatedly.
        Check the number of toggled blinks and proceed to correct the error.
        Error
        Indicator Display Status>
        Blinks orange =The number of blinks differs depending on the error.
        Green/orange =The indicator blinks differently according to error.
        (Toggle blinking)
        User-Recoverable Errors-
        Orange =7 Blinks
        check that error status codes=
        1402 Cartridge error
        1403 (a) The print head temperature (output of the
        1405 diode sensor in the head) is close to the threshold
        1485 (b) Print head internal EEPROM checksum error.
        <Suspect Part>Print head.
        *****7 toggle blinks between Orange/Green
        Status Code= 5B00
        Waste Ink absorbers have reached 100% capacity.
        Unresolvable Errors by the User-
        7 toggle blinks =Orange / Green= Waste-ink full
        The waste-ink absorber has reached 100% capacity.
        <Suspect Part>
        Ink absorber, logic board.
        MANUAL>
        http://rs532.rapidshare.com/files/17...ogspot.com.rar
        or
        http://printer1.blogspot.com/2009/01...ce-manual.html
        password=printer1.blogspot.com
          • 23009
          Trigger addresses this exact bit of confusion. The Waste Ink Code is G-O-G-O-G-O-G-O-G-O-G-O-G-O-GGGGG. The cartridge overtemperature condition is O-O-O-O-O-O-O-G-pause. I have the latter error condition which is the operator code.
          Thanks for the links to the manuals. =^..^=
          • teckat
            • 16083
            good luck/ good read link below/ not that other crappy link
            INKJET PRINTERS INK PAPER Reviews FREE Info |Canon, Epson, WasteTank Solution Refills Inkjetstuff Repair
              • 23009
              It looks as though the difficulty here will be locating an affordable printhead (QY6-0041-010). Of hundreds of google links one sold for $90, the other $75. All others list out of stock or not available. That's too much for the POS printer. I may attempt the cleaning method identified in the post before I walk it to the trash can, though there is no real quality issue. Thanks for the comments. =^..^=
              • teckat
                • 16083
                first try that cleaning method, in link i posted / nothing to lose/
                what about that absorber pad ??
                  • 23009
                  teckat,
                  You're stuck on the wrong error code. I can repeat myself again if you didn't understand. The cartridge overtemperature condition is O-O-O-O-O-O-O-G-pause. This is the error code I'm observing. I could change the feed tire, too, but that's not the problem. How about if we just try to fix the error conditions that are observed and not just make some up? Again, thanks for your help. =^..^=
                  • teckat
                    • 16083
                    teckat,
                    What do u mean about a feed tire/ who is making something up ??/
                    First= You need to address your attitude
                    Second =I provided u with the manual
                    Third=I KNOW IT IS A OVER TEMP CODE, I had this piece of junk before.
                    The information posted was just a reference point for others to look at.
                    • Ikon Princess
                      • 126
                      [B]good luck/ good read link below/ not that other crappy link
                      at least that link actually answers the question. And I would watch your own attitude before being a jerk!
                      • blazebusiness
                        SanDiegoCopierRepair.com
                        • 1257
                        Hmmmm...teckat gives somebody a link to a free manual and trys to give good advice and that equals being a jerk? The problem with that way of thinking is you will discourage him and other people from trying to come to aid in the future. Respect the time he took to make an effort. The beauty of this forum is the way we all make an effort to contribute.
                        Blackcat ... the part you wanted " QY6-0041-010 " is available for $40.82 oem from florida. Email me if you want me to give you the supplier. Hope this helps - but judging from the date on this post - the info I'm giving you is probably too late my friend. I imagine you have moved on to another printer by now.
                        • teckat
                          • 16083
                          I am just wasting my time answering your response, u just now respond to a post from two months ago ??
                          I should not have provided the manual links for S750, it broke Forum rules, I have since apologized to the Administrator. But I will not say I'm sorry to you about that crappy link u posted on/ they are known for giving out misinformation on products.
                          have a wonderful day'
                            • 23009
                            You are exactly correct. It went in the trash several weeks ago. But thanks for checking. =^..^=
                            • teckat
                              • 16083
