Canon IR c3080
  • crazyegg
    • May 2010
    • 10
    Canon IR c3080
    Help! our Canon IR c3080i cannot print, the scanner function works. but the printer is not. Able to access with the ip address in web browser. installed UFR II driver but not working.
    thanks
  • anothertech
    • 1771
    What operating system is you computer?
    32 or 64bit?
    what port did you use when you installed the driver?
    did you try a PCL driver?
    • crazyegg
      • May 2010
      • 10
      Server 2003 , 32 bit. yes I tried PCL6 driver. but non works
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Is this a new unit or one that was working and then stopped?
        Do you have a Fiery controller hanging on the back?
        Go into Additional Funtions -> Report Settings -> Print List -> Printer. Print a PCL or UFR II report to make sure you have the PDL language.
        If you don't have UFR or PCL language installed it won't print, unless you have an external Fiery controller. If you do have a printer language installed look in service mode Copier->Option->INT-Face. Set IMG-CONT to 0.
        • crazyegg
          • May 2010
          • 10
          The copier has the PDL language installed., It was working and then stopped. it worked w. the old ip address, now i cannot change the ip address back. i tried to input the ip on the web brower and the copier itself, but it keep remember the new ip address.
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            Any changes made to the ip won't be locked in until you turn OFF/ON with main switch, the one on the right toward the rear.
            • crazyegg
              • May 2010
              • 10
              D_L_P - thanks, the old IP is working now. But still cannot print, i did not get error messages.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                What UFR driver version are you using.
                There are two kinds of UFR drivers UFR & UFRII
                Is the job even hitting thre machine.
                Check system monitor under the print tab and check the log menu.
                • crazyegg
                  • May 2010
                  • 10
                  We are using UFR II v2.70, there's no job event.
                  thanks
                    • 16083
                    thanks
                    Check in> Additional Functions>System Settings>Restrict Printer Jobs/ is OFF
                    • crazyegg
                      • May 2010
                      • 10
                      i just checked the Restrict Printer Jobs/ is OFF
                        • 16083
                        power on the copier holding down the 2 & 8 keys. Now try pinging the copier with 172.16.1.100. If the machine reply's this means the network board is good, if it does not reply first check your cable and IP address on the PC being used. If both check out OK or you can ping something else on the network replace the NIC card ( LANBAR-C PCB assembly) in the copier, FM2-9611-000. If the unit pings correctly when powered on in download mode but not in normal mode, one cause of the problem was found to be an option in TCP/IP settings turned on.
                        To resolve the problem go to Additional Functions > System Settings > Network Settings > TCP/IP Settings > and turn OFF Permitted Receiving MAC Address Settings.
                        Next power cycle the copier and try to Ping it.
                        • crazyegg
                          • May 2010
                          • 10
                          we do not have problem with using it as networked scanner.
                            • 16083
                            bottom line is , you can not print from your PC/MAC
                            • crazyegg
                              • May 2010
                              • 10
                              before it can only print from server, and cannot print from workstation. now it cannot print from both.
