Canon IR5000 Close Front Door
  • Tim C
    • 167
    I have this IR5000 that keeps coming up with the message "Close Front Door" only after its turned off and back on. You open and close the door and it clears the message, runs copys fine until you turn it off again. Checked all the interlock switches, OK...
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Look around the duplex area, check the rear terminal female and male connectors
    Check Duplex Horizontal Registration Motor M16 and Duplex Driver PCB as well.
    • skkn
      I have Problem like this
      So, Please explain more detials
