plese help me and teach me how to repair my ir6000 finisher , its always come error e535 -004. i have blow all sensor and service solenoid, but also not success,thanks for help.
Ir6000 e535 004
Hope this helps
The swing assembly is the part you see open and close when it is making copies. If you aren't getting any signal the sensor could be knocked out of place.
Another thing to check is the safety switches, the micro switch goes bad or the red cable gets broken from all the up and down motion.
If you know how check the sensor to see if it is good, check the motor to see if it is good. If your motor, sensor and switches check out then may have a bad Finisher controller board. Other thing to check is the one-way bearing on the cam that lifts the swing assembly, but usually that causes jamming or the swing assembly to slam down hard. -
Check the Swing Motor M7, Swing Motor Clock Sensor PI20.Attached FilesComment
