E003 error in Canon iR2016N
  • patil_ps
    • 38
    Hi Friends,
    My Canon iR2016N copier machine is giving E003 error. It is giving this error intermidiately, not everytime. Whenever it given this error, I am doing hard boot [switching off and on]. Can somebody explain what could be the exact reason?
    Waiting for your resposne.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Could be fuser or power related.
    • patil_ps
      • 38
      Fuser means what?
      Complete assy or only Film?
      ANd power related to which part? Fuser assy or ?????
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Thermistors are inside the fixing film assembly. I have never rebuilt one of these fusers, so I can offer no advice on that avenue.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Originally posted by patil_ps
          Fuser means what?
          Use your common sense.
          Change the fuser unit if its due or close to its life expectancy.
          Power supply for power related issue.
          Most likey its going to be a the heater on the fixing flim ass'y.
          • remielee
            Technical Analyst
            • Mar 2010
            • 140
            check the thermostat if theres a continuity using tester (V.O.M) if theres no continuity try to shock it a little bit you can use screw driver or other hard things sometimes the copper inside doesent contack i try it many times and its work. test also the heater like sir screwtape said.
            • patil_ps
              • 38
              Dear Frens,
              I m not able to resolve the issue. Pls guide me. I tried as per remilee said. But nothing has happened. Few days back I had changed the Fuser Film of the unit. Still I have to change the complete unit or just I have to replace the Fuser Film?
              Please help me.
              • blazebusiness
                SanDiegoCopierRepair.com
                • 1250
                Screwtape is exactly right. Replace the fuser assembly to fix your problem ---------or if cost is an issue replace the fixing film assembly FM2-3346-000. This part includes both the heater and sleeve. Replace either one & be done with it.
