imagePROGRAF W7200
  • luigi69
    • 5
    imagePROGRAF W7200
    Please I need help: when I turn on the printer "initializing" appears on display and then,nothing.
    the service manual don`t say anything about this. thankyou so much for your help and I`m sorry for my english
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    The initialization refers to the software being loaded. Normally should take 2 minutes to initialize. If it is stuck in this mode you may have a bad system controller or a problem with the firmware stored on the flash rom.
    • luigi69
      • 5
      • blazebusiness
        • 1250
        Probably the system controller board but it could also be the engine controller but probably not. Unfortunatly I don't think you can flash the firmware when it is stuck in initializing. Lo siento mucho....ojala que no cuesta mucho esa parte. Pueada ser que el voltage causo el problema y para que esto no te pasa dos veces chequea que tiene ground connection. Hay un tornillo que se puede usar si el enchufe no tiene su propio ground connection. Haz me saber que es lo arregla el problema. y tambien si esto te ayuda click la estrella bajo este commentario to ayuda mi reputacion. Adios amigo!
        • mrfuser
          • 1605
          Re: imagePROGRAF W7200
          I had one do this a while back. It was the firmware. You can flash it by this procedure:
          YOU MUST HAVE SAME FIRMWARE THAT YOUR PRINTHEAD HAS OR YOU WILL GET ERRORS!
          Question :
          How do you enter the Download Mode on the imagePROGRAF printers?
          Answer :
          For earlier W2200-Series models: (First, power off the printer)</U>
          Press and hold the UTILITY + SETUP + RESET buttons simultaneously, then press the POWER button. Release the buttons when the message "FIRMWARE UPDATE" appears in the display.
          For iPF W6200/8200 series models: (First, power off the printer)</U>
          Press and hold the PAPER SOURCE + ENTER + ONLINE buttons simultaneously, then press the POWER button. Release the buttons when the message "DOWNLOAD MODE" appears in the display.
          For iPF W6400/8400 series models: (First, power off the printer)</U>
          Press and hold the INFORMATION + STOP + OK buttons simultaneously, then press the POWER button. Release the buttons when the message "FIRMWARE UPDATE" appears in the display.
          For iPF models PRIOR to the iPF650/655/750/755: (First, power off the printer)</U>
          1) Press and hold the STOP & INFORMATION buttons simultaneously, then press the POWER button. Release the buttons when the message "INITIALIZING" appears in the display.
          2) When "DOWNLOAD MODE/SEND FIRMWARE" appears in the display, transfer the Firmware.
          For the iPF650/655/750/755 series:(First, power off the printer)</U>
          1) Press and hold the STOP & NAVIGATE buttons simultaneously, then press the POWER button. Release the buttons when the message "INITIALIZING" appears in the display.
