iR5870
  • waffu22
    • Jun 2009
    • 95
    iR5870
    When i make copies from glass/feeder the paper jam at upper roller and it shows error 800-001.
    Anybody knows this problem please help me.
    Thank you.
  • rosaro75
    • Mar 2009
    • 86
    did you change anything in fuser unit?. check for sound in machine check all fuses in dc controller. if any fuse blown, first you find the short circuit and change the fuse.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      There's a couple of things that can cause this error.
      Make sure the Fixing/Feeding Unit is properly engaged inside the copier.
      Also its is caused by a loss of 24V to the Fixing Interlock with the door closed
      Or a bad DC controller.
