Jam err in imagepress C1 :
  • COCODIAZ
    • May 2010
    • 31
    Hi , (sorry for my english)
    i have a persistent jam error (restart, clear err in service mode)
    in service mode jam list this :
    Time 1 - 1637 / TIme2 1638 / L 0 / code 010D / P 01
    there isnt any paper in the machine
    PD . Where can i get a Service Manual for this, i have for CLC 1120 / 5100
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Code refers you to a delay jam before the inner delivery sensor. When you were in service mode to get the jam code you should have reviewed the jam further. You can Touch any Jam Indication screen to go to the detailed screen of that particular type of jam. It will bring up a diagram of the machine and show you on the display exactly where the jam occurred and give you the sensor involved. I hope that this helps you.
    • teckat
      • 16083
      Make sure your Firmware is updated >System Software version 51.01 corrected an issue where a 010D code could be declared incorrectly.
      There is a great Tech pub on 010D Jams for this model/ came out last year 8 pages . on Fixing Belt Assembly Maintenance
      What were u working on /before issue with Jam ?
      Delay Jam 010D
      Inner delivery sensor
      PS15
      from
      P 01 = cassette 1
      PS5: OHT sensor (front)
      PS6: OHT sensor (rear)
      PS9: Manual feeding paper sensor
      PS12: Registration front sensor
      PS13: Secondary transfer
      rear sensor
      PS14: Fixing assembly inlet sensor
      PS15: Inside delivery sensor
      PS17: Reversal sensor
      PS18: Reversal vertical path sensor
      PS19: Duplex left sensor
      PS20: Duplex middle sensor
      PS25: Side registration sensor
      PS26: Vertical path 0 sensor
      PS27: Confluence sensor
      PS28: Cassette 1 pickup sensor
      PS30: Cassette 1 paper sensor
      PS34: Cassette 2 pickup sensor
      PS36: Cassette 2 paper sensor
      PS40: Duplex right sensor
      PS41: Cassette 3 paper sensor
      PS43: Cassette 3 pickup sensor
      PS47: Cassette 4 pickup sensor
      PS49: Cassette 4 paper sensor
      PS53: Vertical path 1 sensor
      PS54: Vertical path 2 sensor
      PS55: Vertical path 3 sensor
      PS56: Vertical path 4 sensor
      PS65: Paper thickness sensor
      PS76: De curler inlet sensor
      PS78: De curler outlet sensor
      • Van Steal
        • 177
        B]There is a great Tech pub on 010D Jams for this model/ came out last year 8 pages [/B]. on Fixing Belt Assembly Maintenance
        Hi tecket
        You don't happen to have that tech pub please, still having some jams on a few C1s
        Cheers
        • teckat
          • 16083
          Hi tecket
          Cheers
          Good Luck the 010D is a good one/other two are also helpful
          C1-C1+ JAM 010DTP08-6.pdf
          C1-C1+ E007 TP08-3.pdf
          C1-C1+ New 73T Fix Gear TP09-7.pdf
          • Van Steal
            • 177
            Cheers mate
