imagePROGRAF L Printer Service Tool (Ver. 1.40)_ New
  • uflorin32
    replied
    Re: imagePROGRAF L Printer Service Tool (Ver. 1.40)_ New
    Can you help me with a copy of the software? I have a w8400 which starts and remains blocked in "Print head error" ... have cleaned the head, replaced some parts but still can't run over this error and I can't find the software.
    Thank you in advance.
    replied
    What PH Error are u getting ?
    who says L PRINTER TOOL will not work on W6200 SERIES
    Large Format Printers
    iPF500 / 510 / 600 / 605 / 610 / 650 / 655 / 700 / 710/
    720/ 750 / 755 / 800 / 810 / 820 / 5000 / 5100 / 6100 / 6200 / 6300 / 8000 / 8000S / 8100 /
    8300 / 9000 / 9000S / 9100 / W2200 / W2200S / W6200 / W6400 / W7200 / W7250 /
    W8200 / W8400 / W8400D
    Flash/Update firmware on a Wide Format Printer with the L Printer Tool
    Before using the L Printer Tool it needs to be downloaded.
    The firmware used to flash the printer also needs to be downloaded.
    After the L Printer Tool is downloaded and unzipped open up the folder where the file
    was unzipped to and double click the setup.exe file.
  • Jerome67
    Guest replied
    replied
    W6200 FIRMWARE
    USE GARO
    Can this printer can use the GARO Firmware Update Tool to update the versions of the firmware for the system controller installed in the printer.
    The GARO Firmware Update Tool is the same as the one for the user.
    Available software for W6200
  • Jerome67
    Guest replied
    replied
    Originally posted by Quercus
    Where is it possible to find the L-Printer service tool 1.7 (64bit)?
    My IPF5000 drained most of the cartridges during the head cleaning today :--( ... 4 inks went from from 40% to empty :-( and a new MC was filled :-(
    see attach
    L Printer Service Tool Instructions.pdf
  • Quercus
    replied
    replied
    send me your e-mail/ I will send u below/
    u need 32bit or 64bit L PRINTER TOOL v1.70 ????????
    this site is still having issues with attachments
  • paccome
    Guest replied
    Thanks a lot but it´s the same file. It´s corrupt, I can´t open it, I tried with w7 and 7z compressor.Thanks.
    replied
    Originally posted by paccome
    At the canon-asia website I only can find FUTs and I need to downgrade a IPF605.Thanks a lot.
    L-Printer_Service_Tool_E_V1.50.zip
  • paccome
    Guest replied
    replied
    Hi,I´ve downloaded twice the file L-Printer_Service_Tool_E_V1.50.zip but it´s corrupt. If would be possible share the file once more please.Thanks
    Go to Canon Asia website _ look under LFP
  • paccome
    Guest replied
    Originally posted by teckat
    [ATTACH]15152[/ATTACH][ATTACH]15153[/ATTACH][ATTACH]15154[/ATTACH]Lucky Day for All
  • DAG COPIERS & COMPUTERS
    replied
    Hey Mannix, Never ever give up, my brother. ''You could only be 3 feet away from gold''. Help will always come to you from the most unexpected source, it could just be around the corner! I can see teckat is really committed to help you. Wide format printers/Engineering copiers are rare in my part of the world, however, I really keenly followed this thread and it was very interesting. Knowledge never ceases. Good Luck and Keep trying.
  • robsonr
    Guest replied
    Lucky Day for All
    That is exactly what I needed. Thank you.
