imagePROGRAF L Printer Service Tool (Ver. 1.40)_ New
  • drbing
    replied
    I know the post is out of date, but it happened that my ipf 830 got stuck after a power outage. Replenishing ink,2h all set of inks and waste in trash.The question is, is it possible to overwrite the firmware that is already the latest with the same one? Fut doesn't allow me to do that and I can't find any other tool.
  • rodqui6
    Guest replied
    Re: imagePROGRAF L Printer Service Tool (Ver. 1.40)_ New
    Cry my printer is de
  • letstrythisagain
    Guest replied
    Originally posted by teckat
    Have you tested the cover switches
    Could ce a power supply issue
    Not yet. Any recommendations on proper procedure to isolate my problem?
    Thanks in advance
    replied
    Originally posted by letstrythisagain
    Yes I'm connected via crossover cable and am operating on a 64bit. Thank you so much for the attachments, I was finally able to update the firmware to the latest version but to no avail. The "Close Upper Cover" message is still displayed.
    Does this sound like it could be my cover switch voltage? Or am I just being too hopeful in thinking I can do anything other than replace the main board?
  • letstrythisagain
    Guest replied
    are u connected with a Crossover Cable
    are you using the 32bit or 64bit L Printer Tool
    see attachments---------------------------------------------
    https://www.dropbox.com/s/5l89nl9iph5cnwi/L%20Printer%20Tool___1.80%20Info.pdf?dl=0
    https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-imageprograf-printers/imageprograf-ipf605
    replied
    Hello
    I too have a Canon iPF605 with the ever-present "Close Upper Cover" message (and of course it is closed).
    I also fear that the inevitable end will be to replace the main board. But until then, I have endlessly been researching my options.
    In my effort to try the L Printer Service tool (V 1.50) to update the firmware (Service mode does not work/am able to get it to Download Mode) I can only get as far as the "Setup" step for which it says that my operating system is not supported. This is not true as I have the correct FUT/Firmware/OS and have tried them on multiple computers but yet it still will not budge.
    So does anyone have any advice on these two subjects?
    1) What to do about the operating system fault? (Is there another version that I could use? I have multiple different operating systems including Windows 7 64/Vista/Mac)
    2) Should this not work, could it be my cover switch voltage?/What would be the best route to fixing it?
    Thanks so much!
  • letstrythisagain
    Guest replied
    Hello
    Thanks so much!
  • jayskee
    replied
    Thank you for this, I am well aware.. 1.43 is what has caused this issue in the first place, I need to downgrade
    Please refer to my thread: http://www.copytechnet.com/forums/ca...tml#post522775
    Or PM If possible
    Thank you!
    replied
    Originally posted by jayskee
    G'day,
    My canon IPF8100 printer was working perfectly until I recently upgraded the firmware.
    Since then it is throwing massive errors in relation to the heads.
    I have noticed this is a common issue with the new firmware and many have solved the problem by downgrading to firmware 1.34
    Unfortunately, I cannot find this firmware anywhere as Canon has deleted all of it's old firmware
    If anyone could please direct me on where I could access firmware 1.34 or any other possible solution it would be greatly appreciated.
    This has cost me 4 business days already and I am very eager to get this printer working again.
    Thanks in advance,
    https://www.usa.canon.com/internet/p...B0AMD0F1Q42K25
    ver. 1.43 is here
  • jayskee
    replied
    G'day,
    Thanks in advance,
  • Netti14
    replied
    may need to change that Main Controller
    I think, it's the best way! Too many error's....
    replied
    replied
    Check for a change of state for sensor.
    Sensor has three leggs.
    Ground, Signal Change, Supply
    Best to check Signal change output in connector from board, & not across load (photo sensor itself)
  • Netti14
    replied
    when I'm going to service mode, the same error comes (E196-404E)!
    I can't enter the service mode to reset the error....
    update: The voltage at sensor is too low. It must be 3.3V there are only 1V. Measuring at the power supply and the two voltages there comes out, are also tooo small....must see...
  • Netti14
    replied
    did you have this specific manual for iPF605?. I have only a service manual iPF6000 series, but there I can't find voltages for the sensors.
