ir c3100 e0067-0100
  • lightningjeremy
    • Jul 2009
    • 139
    ir c3100 e0067-0100
    service manual just states to repower machine, what is actually going wrong? it says primary transfer atvc is wrong. whaty does the atvc stand for? thanx
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Try replacing your drum unit.
    • lightningjeremy
      • Jul 2009
      • 139
      thanx screwtape. i was reading more into the atvc. could the primary transfer roller be bad?
      • lightningjeremy
        • Jul 2009
        • 139
        the drum did not fix it
        • lightningjeremy
          • Jul 2009
          • 139
          ended up being high voltage sub pcb. thanx for the help
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1257
            In my understanding The copier does an automatic complicated mathmatical calculation to determine what the optimum transfer value for current (ATVC) should be based on its equations - then it measures the actual current to see if the value is within tolerance of the expected value . A problem with the voltage supplied by the hv sub pcb board - which is what you had- or a drum out of tolerance range can throw this code.
            When you install a itb for the first time or replace one you run 1ATVC-ex in service mode which the copier probably uses the result as a reference to compute the expected values based on a mathmatical table.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Nice fix.
              Thanks for posting back.
