Ir 5000 fixing feeder assy
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    I have an IR 6000 parts machine. Just out of curiosity ----- can the entire fixing feeder drawer assy be removed and slid into an IR 5000 or is the wiring on the whole assy different. Thanks in advance for your replies.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    I don't see a problem. Its the same to me.
    Try it!
    • blazebusiness
      • 1257
      will do - thanks for replying amigo........... I can't imagine that they are different but I've been surprised B4
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        They are completely the same, fuser hardware-wise...
        • teckat
          • 16083
          if it don't fit, you know who to call
          • blazebusiness
            • 1257
            Its the wiring to the big connector on the back that worries me ... I know all the parts are the same and it will fit into the machine just fine. I'll try it today and let you all know. Thanks again to you guys. You're always prompt in responding.
            • mrfixit51
              • Oct 2008
              • 1975
              The differences in the 5000 and 6000 family are in the controller cage.
              • blazebusiness
                • 1257
                Thanks MRFixIT
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Its the same all the way.
                  The part number is the same for 5000/6000 - FIXING/FEEDER FRAME ASSEMBLY--FG6-5086-290.
                  And the fuser is the same. Same part number - FIXING ASSEMBLY--FG6-5084-000
                  • Alan Aya
                    It is the same provided it is the same voltage (115volts and 240volts)
                    • teckat
                      • 16083
                      so will the Fuser~~~~~~~~~~~~~~~~~
                        • 23009
                        You should have no trouble taking the whole assy. As was previously posted, all the programming & speed differences are on the DC controller, not in the RDF. =^..^=
                        • blazebusiness
                          • 1257
                          To close this thread - thanks very much to all who replied....and yes they are identical !
                          • teckat
                            • 16083
                            Read all about ~~~~~~~~~~~~
