Is there Anyone In the Flint, MI area who can fix my copier clc900
  • LGEM
    I keep getting an error code E010 and it cuts off.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    It sounds like you are trying to get a technician to do this "on the side".
    PLEASE, do yourself a favor, and get service through an authorized Canon dealer.
    If parts are needed, you can only get them from a dealer; even if the "moonlight" tech worked for a dealer, he'd most likely have no way to legally get you the parts you need.
    Keep in mind that a CLC900 isn't exactly a machine for amateurs or beginners; you need a real tech.
    You also have the issue of warranty on the work performed, that only a legit dealer can provide.
    While the dealer's labor rates will be higher, it will be way more than worth it in the long run.
    • teckat
      • 16083
      E010
      too many things to go over on this out of production printer
      -The main motor (M4) may be faulty.
      -The main motor drive system is subjected to an overload.
      -The main motor driver PCB may be faulty.
      -The DC driver PCB may be faulty.
      -The CPU PCB may be faulty.
      heed the advise of KenB
      • SCREWTAPE
        East Coast Imaging
        • 3396
        CLC's are good machines
        But, its time to advance to modern technology
          • 23009
          I'm not far, but I haven't worked Canon Color. Like Ken said, you really need a qualified guy with this model. =^..^=
          • teckat
            • 16083
            Give Mike's agent a call> 310-248-2000
            / he can fix anything/and knows your area (:
            • charm5496
              • 2387
              You need a front door switch. WC8-5051-000.
              If you need instructions let me know. It is not that difficult to do if you can not find a tech.
              • teckat
                • 16083
                could also be a door magnet issue
