ir6570 copy problem
  • universaltvm
    • May 2010
    • 52
    ir6570 copy problem
    i have a ir6570 copier , i made around 9lakhs copy frm it , now i am having a problem with this machine, i am attaching the black out of the printout, it is coming on both copy & printouts
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    When you say "printout" do you mean a test page 6 from service mode? That looks like a normal sky shot form a digital copier, they pick up reflected light with the lid up.
    Have you replaced the corona wires?
    If you are making heavy fill copies I think there is a setting in service mode to increase the amount of toner added in the developer so it will keep up with the demand. I'll look that up and post later.
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      As the man said , is that a skyshot?
      If not it looks like the Primary Fan Duct on the front of the machine has broken one of its screw holders.
      Cheat the door and push it in with your finger , see if you get a change.
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        I've seen this before. I would start with the corona ass'y.
        Primary
        Pre-Transfer
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          I'm with Mr. Screwtape on this one----Coronas ---- wouldn't mind it though CanonSco - if you could elaborate a bit more on why the fan duct would do this. Just curious.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            I started to think the same. Why would this matter??
            After all the fan duct panel or primary front cover panel, what ever we call it. This panel opens up the laser shutter.
            I guess it could effect the laser beam sightly, but im sure a E100 would occur.
            • universaltvm
              • May 2010
              • 52
              Primary
              Pre-Transfer
              i have checked all this things
              • CanonSco
                Man About Town
                • Jul 2010
                • 368
                Yes , laser beam effected.
                Seen it enough times to now carry the Fan duct. Only on 6570's though.
                You can repair them though. Is a very easy thing to check.
                Out of the first half dozen I saw, only 2 had E100's in the history.
                In fact the first one I saw was suffering from exactly the kinda shot of the OP plus E100's. So of course I went down the route of replacing just about everything
                Stumbled across the broken plastics by accident whilst cheating the door and by chance leaning on it.
                Yes, I am a nerd.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Its quite relevant.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Have you try replacing these components?
