IR3300 Fax Image on Report
  • dbmoylan@gmail.com
    • May 2010
    • 89
    Might anyone know which setting will place a portion of the faxed image on the report sheet that prints after a fax is transmitted? Thank you.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Additional Functions-> Report Settings->Send(left column)-> TX Report.
    Turn it ON and set error copy print to ON as well.
    Hope this helps!
      • May 2010
      • 89
      Thank you - will do.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        To add to DLP.
        I think you should see a option that states.
        [Set the Report with TX Image option to ON]
          • May 2010
          • 89
          Thanks Screwtape, will check to see if that exists - don't remember seeing that option, though was trying to locate.
