GP605 ADF
  • jiongpao
    • May 2009
    • 414
    GP605 ADF
    Hi all. GP605 here working fine just when i use the adf for the set copy, some pages are out of alignment evenly, i mean almost all of them. they went up n down in few centimeters till cnt see the bottom or top of the wording. Using manual copy is fine and i dont think it setting problem since i saw theres no adf adjustment in XY inside service mode. Any possibility on part failure?
  • teckat
    • 16083
    FEEDER>ADJUST
    Level 3
    DOCST
    Adjusting the Original Stop Position for Pickup from
    the Feeder (original tray pickup)
    Operation
    1) Select DOCST.
    2) Place paper on the tray (A3/11"x17").
    3) Enter a setting using the keypad.4) Press the OK key.
    • The paper on the original tray will be picked up and
    stopped on the copyboard glass.
    5) Open the feeder slowly, and check the position of
    the paper.
    6) Close the feeder slowly without removing the paper.
    7) Press the OK key.
    • The paper on the copyboard glass will be delivered to
    the original tray.
    8) If the stop position is not as indicated, go back to
    step 3), and make adjustments once again.
    Range : -50 to 50 (Each '1'
    causes a shift of 0.5 mm)
    • The data is retained by
    the ADF controller PCB
    on the feeder side.
    Items under FEEDER>ADJUST
    Level 1 Level 3 Range Description
    ADJUST DOCST -50 to 50 Use it to adjust the original stop position.
    DOCST-M -50 to 50 Use it to adjust the original stop position (for manual feed).
    LA-SPEED -54 to 54 Use it to adjust the original feeding speed for stream
    reading mode.
    STRD-S -25 to 25 Use it to adjust the original stop position for stream
    reading mode (for small-size).
    STRD-L -25 to 25 Use it to adjust the original stop position for stream
    reading mode (for large-size).
    RVM-SPD -30 to 30 Use it to adjust the reversal motor speed.
    Level 3
    DOCSTM
    Adjusting the Original Stop Position for Pickup for the
    Feeder (manual tray pickup)on the feeder side.
    • jiongpao
      • May 2009
      • 414
      .................... omg it seems like big problem gonna read carefully
      • jiongpao
        • May 2009
        • 414
        Thank you. From Teckat information and SM today i just try on adjusting the horizontal and vertical position, it work perfectly. First i thought its in service mode for the adf adjusting that similar like IR family.
        • teckat
          • 16083
