IR 8500 wait message
  • xcopytech
    • Aug 2006
    • 1792
    After paper jam, machine could not continue to print, wait message on screen, can hear machine "working something" but do not print out anything.
    No error code.
    After restart machine everything is ok.
    Also this is not case with every paper jam, just sometimes.
  • shazza
    • Nov 2009
    • 96
    Hi,
    Possible causes
    Wait Screen Does Not Go Out
    Faulty Main Controller / Memory
    Replace Main Controller
    Put A New Set Of Memory In New PCB
    finisher power cord assy
    CB1 circuit breaker on Finisher k3/k4
    reset CB1
    SHazza
    • Alan Aya
      No error code.
      When the wiat message comes on, did you check the fusing temperature? COPIER>DISPLAY>ANALOG to see the functionality of the Main & Sub thermistor. Also check the connection of unit 1 with the machine. Sometimes the remaining of the jamped paper could have stuck into the connector when pushing in the unit 1 after clearing paper jamp.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        I'm with the fuser temp.
        Check COPIER>DISPLAY>ANALOG as mention.
