**322 code on a Canon fax
  • Jimbo1
    • Mar 2008
    • 845
    Is there anyone out there who can enlighten us on what this code means?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Which fax device do you have?
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      As Screwtape alluded to, the model of fax, or copier with fax board installed would be helpful information. My suggestion is if it is a copier with fax board, to look in the fax service manual for that particular device, that is where the codes are listed. I checked my listing of generic codes, and ##322 was not listed on it...
        • 22999
        It's relatively common on the LC5000/7000 series facsimile. It's a fuser code, but may also be caused by the power supply if you are also getting ##330. This fuser is similar to those used on common HP printers, so individual parts may be available. =^..^=
        • Jimbo1
          • Mar 2008
          • 845
          Thanks Blackcat. Man you are everywhere.
          Cdr. William Riker
