Canon LC 3170 check printer error
  • kennyoleary
    • Aug 2008
    • 23
    I have a Canon LC3170 that is flashing the message check printer. I have removed the paper drawer, fuser and cartridge and there is no jam. Switches seem to be working properly. I am not sure what else to look for. Any help would be appreciated. The machine is set up only to send and recieve faxes.
    • 23009
    Are you seeing an error code? i.e. "##322"
    • kennyoleary
      • Aug 2008
      • 23
      No error other than check printer
        • 23009
        If there are no other error messages, you must have a paper feed flag actuated somewhere or a door open. =^..^=
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Hey 'Cat, doesn't he need to turn on sw1 error message flag so he can get a numerical part to his error message?
            • 23009
            Wow! I haven't thought about that in years. Is that softswitch defaulted to Off when new? All the machines that left our location must have been changed at setup.
            If the wrong paper size is loaded (tray not programmed to the correct size), the error will clear, but jam again immediately. =^..^=
            • mrfixit51
              • Oct 2008
              • 1975
              Wow! I haven't thought about that in years. Is that softswitch defaulted to Off when new? All the machines that left our location must have been changed at setup. =^..^=
              I believe they are/were,,, as I recall it was SW1 , least significant bit, bit 0??? all the way to the right ;-)
