ir 5065
  • otreb
    • Aug 2025
    [CQ] ir 5065
    having problems with ir 5065 half faded copies replace corona wires and also assembly s
    make solid black copies good ran 11-17 see if drum had dead spot but it looks fine.
    thanks
  • SCREWTAPE
    East Coast Imaging
    • 3396
    There are three corona ass'y.
    Which one did you replace?
    • otreb
      replace all of them
      • SCREWTAPE
        East Coast Imaging
        • 3396
        What's the meter on this unit.
        How are you making copies?
        Have you checked potential control?
        • Paul 75
          • Oct 2008
          • 97
          Check the laser shutter actuator on the front of the Process assy. It will copy and not give you E100 but it doesn't make the shutter go in enough. I've had this a couple of times.
          Oh...... I can't copy at the moment then ? !!!!!!
          • SCREWTAPE
            East Coast Imaging
            • 3396
            See this happen.
            That's a validated suggestion.
            • otreb
              meter is341,127, feeder and glass,i check the potential controller turn it on and off
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Your making copies from the glass?
                Check your optics, on the machine and feeder.
                Clean them if there dirty
                Also for the hell of it check your fuser section. Make sure your bushings are ok and not broken, it can cause a uneven amount of pressure when fusing toner to the paper.
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  Is the drum heater turned on? In these high humidity days, it can make a real difference in overall copy density...
