iR 6800 Error E000061-0008
Drum Phase Adjust:
Enter Service mode
Copier>Function>Misc-p>dr-p-adj
check it and press ok, the mashine does the adjust automatically and the result should be an *OK* popping upIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
The whole purpose of drum phase changing, is to keep the image area moving on the drum to reduce electrostatic fatigue."Once a King, always a King, but once a Knight is enough!"
250,000 copies is the factory spec for this, doing it earlier will not harm anything, be sure to reset drum phase counter so the copier won't start nagging you to do it later..."Once a King, always a King, but once a Knight is enough!"
