If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
Not after 2/3 sec after turn on. When I turn on machine start to warm up when finish it start to enter into gradation process when it is in that process it start to rotate the whole mechanism I think its 3, 4 seconds then it stuck
Yes I know how to remove it I use its service manual because it is my first time to deal with this big machine, before I was manage to fix replace yellow cartridge issue so now I have the code error mentioned, About the drum its okey it rotate, On my service manual I was try to search for those Sensor I discover things like this. on link ir 6800
Hello my brothers I have got a new service manual From tectat and I have found the following information:
15.3.2.3.7 Extreme fogging due to poor connection of LED array for pre-conditioning unit/Occasional E061-0003 Error Code
0009-9283
iR C6800
[ Inspected by Canon Inc. ]
escription
Extreme fogging occurred on images (including non-image area) because the connector [1] (J206) of the LED array inside the AP kit had poor connection.
As a result of inspection it was also found that E061-0003 sometimes occurred and E061-0008 was recorded in the error history.
Field Remedy
When a symptom occurs, re-insert the connector on both the LED array and AP kit sides.
0009-9283
iR C6800
escription
Field Remedy
Hello,
I need your help on this printer when I turn it on it start waming up when it start initializing the whole system it stuck and pring this error message.
Sam From Tanzania E.Africa
Potential sensor or potential sensor connector could be the problem. E061 can also be the laser unit problem.
Check the potential sensor connector (1 of the 5 connector) in front, u need to disconnect it when u want to service the processing unit.The wire could have been broken due to pulling of the wire when disconnecting the connector.
I think those connection they are located at the light side in front. if its that their okey.
Has the drum phase ever been adjusted on the machine yet? This could also cause an issue.
Am not sure because It has passed to more than 4 tech here in Mwanza, so am not sure if it has been adjasted, You can give me a tips to know if it has been adjasted.
Thanks let me start this mission because here in Tanzania its imposible to find those iquipment..thanks thanks
May I correct your statement of equating difficulty to impossible. In fact it is difficult to find those parts, but when you admit to be impossible, you automatically cease to keep on trying.
If the problem is not solved yet, give a call on 071 324 5522.
Regards!
