iR-c3200 - Colors out of alignment.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    #31
    Re: iR-c3200 - Colors out of alignment.
    As you seem to have covered all the mechanical bases, you might try clearing
    DC-Con and re-entering your data.
    BUT ONLY DO SO AFTER OBTAINING A P-PRINT OR LABEL PRINT!!
    Failure to have those printouts stored with the machine will be a grave mistake.
    You can try the Clear operation and test the print registration without re-entering
    the saved settings yet. You will know right away if that helped, but by all means,
    do re-input those settings.
    good luck
    • Adrian_Boy
      • Dec 2014
      • 19
      #32
      This is the home positioning, or be less adjusted?
      • teckat
        • 16078
        #33
        [ATTACH=CONFIG]27945[/ATTACH]
        • Adrian_Boy
          • Dec 2014
          • 19
          #34
          Ok... i see now, thanks again Mr.
