saddle fin ad
  • roho
    • Mar 2009
    • 844
    [Misc] saddle fin ad
    I see the specs for the saddle function for 80gsm paper is 15 sheets including cover.
    Yet the fin will not saddle stitch unless less the originals on the adf are less then 60 ltr.
    58 originals to be exact. From the manual, I would assume that 60 ltr originals at 4 up would be able to stitch.
    Is this a specification matter, or does an adjustment need to be made?
    Thanks!
  • teckat
    • 16083
    Thanks!
    what model machine ?? & what model finisher ?
    • roho
      • Mar 2009
      • 844
      Sorry, saddle finisher ad1-ir 5050
      • teckat
        • 16083
        it may be miscounting orig in Dadf/ clean sensors
        u mean AD-2 & DADF M-1
        M-1 can hold =up to 100 sheets @ 20lb 80g/m
        AD-2=15 Sets 60 pages- LTRr- 11x17- Legal
        Try and turn on the Saddle Stitch Delivery Tray Limitless Mode
        Turn On Saddle Stitch Delivery Tray Limitless Mode.
        To allow continuous stacking of booklets regardless of the stacking capacity.
        How to bypass the maximum number of booklets stacked in saddle stitch finisher.
        With the following dip switch setting the user is now allowed to stack saddles continuously, regardless of the sheet stacking capacity even if the number of the saddles that can be stacked is exceeded.
        ** Remember, the booklets will need to be removed intermittently or else they could jam the finisher.
        Enabling the Saddle Delivery Tray Limitless Mode
        Turn off the iR.
        Set the bits of SW104 on the finisher controller PCB as follows:
        Turn on the iR.
