e000002-0010 in Ir 6570
  • copymaster2000
    • Dec 2007
    • 28
    Sir,
    I m getting e000002-0010 in Ir 6570.Touch screen is also not functioning at this time.
    Can u help me out to clear this error please?
    Regards,
    Copymaster
  • teckat
    • 16083
    Originally posted by copymaster2000
    Sir,
    Regards,
    Copymaster
    first remove fuser unit & check
    if all ok, go in service mode & do an ERR CLR
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Clear the code first, shut down and check to see if the machine comes up.
      Then check the fuser unit, check the conditions of thermistors, clean them if dirty.
      Check the pressure roller and bearings for seizing.
      If the code comes back, replace the thermistors of what seems to be at fault within the fuser.
