irc3220 w/C2 red lights 2&3 stay on
  • copierpro
    • Apr 2007
    • 270
    Got a C2 that at boot cycles then the red lights for dip 2&3 stay lit and cannot print to the c3220. Anyone got a reset fix for this or what I might look at? Just happened all of a sudden printer has been working great 4 months at customer site.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Offhand,,, power down the C2, open the can, reset all the components and cables, try again. If still not coming up, a software restore seems to be in order. Those are the steps I would try...
    • Canuck
      Tech Specialist
      • 1713
      Don't forget to pull the NVM battery out and leave it out for 10 minutes
      • copierpro
        • Apr 2007
        • 270
        cable reset power up tried it
        We have already checked the cables, components all secure power up still getting the red lights.
        I don't have the manual but isn't software reset press and hold 1 + 9 and power up? Or is that in service mode? I can't remember. Instructions for service mode entry appreciated.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          The red lights your talking about are on the C2 right??
          They should read 00. This is good.
          I'm a bit confuse however with what your stating.
          Dip switch 2&3, what is this your refering too?
          1&9 is to do a defrag on the copier HDD.
          *2&8* is service mode.
          Are you having a problem with the Imagepass C2 or the IRC3220
          • copierpro
            • Apr 2007
            • 270
            red lights C2
            The big problem is customer is in SC and I am in FL. In any event, when he was first using it, and as I recall the C2 booting up, 4 leds cycle at boot up then all go out when it is at ready.
            Customer says this is correct - all leds would go out when at ready. He states the top two leds now stay on and he is unable to print. I had him check cables, power doen the up, and the two red lights on C2 still stay on.
            The prblem is definately with the C2 and I think a software reset in fiery setup may do the trick? what do you think?
            • Canuck
              Tech Specialist
              • 1713
              As stated take the cover off the imagepass and reseat everything. Removing the round battery will reset it. Rebooting wont work. Like Screwtape said it should display 00...probably showing FF.If no display on it then its a c1 (could be upgraded to c2 software)
              • teckat
                • 16083
                U mean Red LED Lights on small Diag. Screen/on C2
                it may be showing E3 / and Looks like 23
                only one set of dip switches on C2 unit/ used for downloading software/ both in up position for service/both down for normal operation.
                Only remove battery if u are showing a FF on LED window
                FF - The imagePASS is not booting up. Check external and internal connections and cables.
                E3 - DIMM is missing. Install or re-seat the DIMM in DDR DIMM2.
                00 - The imagePASS has booted and is functioning properly.
                imagePASS C2 / G1 / H1 / J1 E3 Diag Error on the imagePASS C2 / G1 / H1 / J1 If you see the E3 error code on the diag display, it means that the RAM chip [DIMM] is missing. To resolve the problem, install RAM in the DDR DIMM 2. If this chip is already there, re-seat the memory stick.
                DIAG LED SCREEN:
                • teckat
                  • 16083
                  FF error code may occur due to one of the following causes:
                  1. A power fault (surge, sag, or spike) in the line voltage supplied to the imagePASS may cause a bit in the CMOS to be incorrectly changed. Since data stored in the CMOS is backed-up by a battery, the incorrect bit setting is retained in subsequent power-ups. When the FF error is caused by a power-fault, the error can often be cleared by resetting the CMOS. This can be accomplished by removing the CMOS battery and shorting the positive and negative terminals of the battery holder.
                  a. After clearing the FF error, the CMOS battery may be reinstalled. Unfortunately, if the battery is reinstalled, a future power fault could cause the same error to occur again. In order to prevent the FF error from reoccurring, the CMOS battery should be removed permanently. As the CMOS battery is responsible for retaining clock (date and time) information on the imagePASS, a patch (1-Q3WR9) has been created to allow the imagePASS to obtain date and time information from the imageRUNNER that it is currently attached to.
                  b. In the future, the motherboard of the imagePASS-C2 and imagePASS-G1 will be modified at the factory in order to prevent the incorrect bit change when a power fault occurs. For imagePASS units with the modified Motherboard, removal of the CMOS battery and applying the 1-Q3WR9 patch will be optional (in those cases where the customer wants the imagePASS to synchronize date and time settings with the imageRUNNER, the patch can be used).
                  2. The CPU may not be seated properly on the Motherboard. If the FF error code is caused by an improperly attached CPU, then the CPU must be reinstalled correctly in the CPU socket in order to resolve the error.
                  • copierpro
                    • Apr 2007
                    • 270
                    site freaking out
                    continually starts to load then stops then reloads in browser too much advertising crap all over the place!
                    • teckat
                      • 16083
                      What are you talking about ????
                      clean up your junk & cookies/ and allow pop up for this site
                      • mrfixit51
                        • Oct 2008
                        • 1975
                        I have switched to Firefox to visit this website, it runs smother for me than IE ever did, especially during the "facelift" the site went thru many moons ago...
                        • Canuck
                          Tech Specialist
                          • 1713
                          Microsoft junk...I run a Linux kernel based operating system 3/4 of the time....no anti-virus,or any of that crap! Browse with Firefox...will totally be migrating from Microscoff in a month or 2
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            Microsoft junk... I think not...
                            I too have a box running Ubuntu 10.10 beta. But my work PC needs to live in the Microsoft world, where all the software needs to run on a windows platform. Linux can be fun, but it limits what you can do based on application limitations...
                            • Canuck
                              Tech Specialist
                              • 1713
                              I know what you mean...my work laptop lives in the Microsoft world...but things are changing. Ubuntu is a pretty limited distribution(OS)...good for running Backtrack and other goodies. Thats whats so nice about Linux and open source stuff....you can designed the OS to tailor to different needs. But realistically its a Windows world. Have you ever tried Opera as a browser running on Windows? It scoots...running through it right now
