Canon ir 105 Problem
  • jzheld
    • Sep 2010
    • 162
    [Misc] Canon ir 105 Problem
    Canon 105 started to act weird, when I'm doing copy, it grabs paper from the tray and than stops, the sound is like it's printing, but nothing than just keeps saying "Reboot this device" after reboot the same thing. Does anybody know what can be a solution?
    Thank you
  • watson
    • Sep 2009
    • 64
    You probably need to get rid of the reboot message by clearing the message board and check your jam codes and try other trays.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      How does the screen look. Is it red when it says reboot this device.
      Are there numbers showing, like E000xxx-xxxx
      • jzheld
        • Sep 2010
        • 162
        there are no error messages screen is fine, I just find out that I can print without any problems even when it saying "reboot this device" but I can't copy, paper always stops under bay pass tray
        • Herrmann
          • Jan 2006
          • 792
          check the connection between scanner and printer unit
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • jzheld
            • Sep 2010
            • 162
            I just got E000732-0001
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Had this issue with an iR5055 this week, copier was shoved up against a partition and the scanner cable was getting crushed. Re-seating both cables resolved my issue.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Check your cables and connectors on the reader and main unit.
                • jzheld
                  • Sep 2010
                  • 162
                  Thanks that helped but for long, still have "reboot this device" on the screen, printer and copier works, but sometimes still getting error 000069-0000 usually after 5-6 pages of the large job, 2000-3000 pages, small ones are ok. I understood that cable can be a reason but which one, should I replace the cables? if it's possible.
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    E069 has to do with the transfer/separation corona assembly. If it's life is over 100%, replace it, otherwise, restring the corona and see if that takes care of it...
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      As mrfixit noted for the E69
                      Replace the transfer sep corona.
                      • jzheld
                        • Sep 2010
                        • 162
                        Thanks a lot, going to replace it tonight
                        • macuk
                          • May 2009
                          • 90
                          check for wear on the fuser pressure roller and bearings as well. The metal filings have been known to get into bearings and interfere with the bias on the upper fuser roller. this can give E069 as well.
                          • Canuck
                            Tech Specialist
                            • 1713
                            If you put the plastic collar on backwards this is what happens...the end of the upper fuser roll rubs and shaves off aluminum. Fuser bias shorts to ground, The contacts at the rear of the machine that the transfer contact pin on the drawer plugs into get deformed alot
                            • "Harvey Dent"
                              I've seen this happen on a IR8500
