I run single side, no paper jam. But if do double side, for only 1 sheet no paper jam problem also. But if i run double side (more sheet per sets) for offset collate, paper jam 0205,0209 come out...
IR 105 paper jam code 0118
Check you connectors in this area.
Again bad clutches in the registration area and pick up assy can still cause these types of jams.Attached FilesComment
Check for a burnt pin on the connector for the right deck .. could have been burnt by a tech removing the right deck feed head with powering off the copier ( screw falling the pins or being touched by a screwdiver .. i have done it myself )Comment
Sorry for my bum steer earlier in the thread, I just rechecked my 105 digital service manual, and the copier jams list ends at XX17 ??? Guess a I need a newer version of that digital manual..."Once a King, always a King, but once a Knight is enough!"
imageRUNNER 85 / 85+ / 105 / 105+ / 7200 / 8070 / 8500 / 9070
Finisher-K3N 1125 Jam Code
A jam code of 1125 occurs intermittently in the Saddle Finisher-K3N. Paper is jammed after the saddle inlet sensor prior to the buffer rollers.
The cause of the intermittent 1125 jam was a bent arm on the punch die slide. This arm has a green handle attached to it and is utilized during jam removal when paper is located in the punch assembly. This arm would contact adjacent frame areas causing a slight shudder in the movement of the paper and punch dies. The arm was reformed to provide for proper clearance and movement. Reference picture below for location of jam removal arm.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Saddle Finisher K3 / K4
1125 Jam
The 1125 Jam can occur if the actuator for PI59 is not jumping back fast enough. If the issue occurs, try adding a wrap to the spring for PI59.
By the Way, Now it no longer running like a horse...Today My IR105 DC board burnt...At 1st i tot Hard-disk....Coz it running half way then hang...Then it continue to run 2 sheet then...and so on...Suddenly machine black out and i smell something burnt. thought hard-disk but then DC-board. So, Is it the Ir105 DC same with 85?Comment
IR105 error 0118
Jam error 0118 is caused by delay in paper travel from the paper deck to the registration. Clean or replace paper feed rollers and paper path rollers (from the side) and the registration roller. Make timing pattern on a piece of paper and make copy. Compare the result to the original, check for any delay. Make more copies and compare all the copies to see if the timing changes.Comment
Jam code was fixed by poster/ issue now is a Fried Connector /HDD or PCB.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
