canon np6050
  • horsesh
    canon np6050
    I am not a tech. I am a member of a really small volunteer fire department was was donated a canon np6050 printer with no documents at all.
    I am trying to get the machine to work. It powers up fine but stays on enter id number. At that point, using the keypad does not change the zero's in the display screen. We can not afford to bring a tech from the city all the way out here to Horseshoe Bend Idaho...any help would be great!!!!
    Thanks.
    • 23009
    To Cancel ID Mode
    I must had had to figure this out once, long ago.
    To cancel ID Mode:
    Press *, ID, Stop, *, Store User ID#, OK.
    Press Clear All ID#s, OK. (Storing all ID#s to 000000 will also cancel ID Mode.
    Good Luck!
    • horsesh
      thanks
      It worked. Thanks alot. Now to try to restring the belt for the lights on the scan bar. What a pain.
        • 23009
        Wire rope?
        Are you talking about the scanner cable? That is very unusual for that to come off. Watch for any damage to light source one (the section that has the exposure lamp). If it takes you less than one hour you are pretty damn good.
        • Canuck
          Tech Specialist
          • 1713
          Carriages have to be in proper positions..good luck...cover your eyes when you run the first copy
