Document size
+ More Options
Posts
  • blu3sky
    • Jul 2010
    • 25
    [Misc] Document size
    hi, i've canon IR5000 and i want to off the sensor document size, which annoying in function image repeat.
    please help me
  • teckat
    • 16083
    please help me
    for Glass copies>
    COPIER>OPTION>
    SIZE-DET
    Use it to turn on/off -the original size detection mechanism.
    Settings 0: OFF, 1: ON (default)
    Caution -After making the setting, be sure to turn off and then on the main power
    switch.
    COPIER>OPTION>
    OP-SZ-DT
    Use it to turn on and off -the original size detection mechanism in book
    mode.
    Settings 0: OFF (accepts input of original size from control panel; default)
    1: ON (detects original size automatically)
    for ADF>
    COPIER>OPTION>
    SCANSLCT
    Use it to turn on/off- the ADF original size detection mechanism.
    โ€ข When ON, the scan size is determined according to the detected original
    size.
    Settings 0: OFF (default), 1: ON
    • "Harvey Dent"
      Will this help for a related problem I've come across. I have a problem when I put copy on glass it reads 11x17 but the paper is letter.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        I believe this might help.
        Enter service mode:
        Level 2/ Copier/ Option/ Body SENS-CNF = 1
        SENS-CNF =0 (default) : AB Type Document Sensor Placement
        SENS-CNF =1 : Inch Type Document Sensor Placement
        At set up or after clearing ram, the value will return to default (0)
        Somebody must have cleared Rcon's ram.
        • "Harvey Dent"
          Thanks screwtape. Once again your fast response is appreciated. I will check this out.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            No problem.
            Anytime.
            • blu3sky
              • Jul 2010
              • 25
              thank you teckat
              , but at my copier 1 for off
              • blu3sky
                • Jul 2010
                • 25
                Enter service mode:
                if that topic, at my copier there isn't sens-cnf but model-sz it the same with sens-cnf
                • teckat
                  • 16083
                  thank you teckat
                  the settings I posted for you are for your situation that u posted for/ u wanted to turn off Auto sensor Reads for Glass copies/ I also included a turnoff for ADF auto read/
                  u requested an adjustment for "AUTO DETECT TO BE SHUT OFF"
                  please help me}
                  When u turn off Auto Detect / for Glass and u put a document with a size other than those loaded in paper trays =u will be prompted to select the tray to print from.
                  If Auto Detect is turned off for ADF/ When u put a Document in tray> after pick up and read, if Document is different size than paper loaded/ u will be prompted to choose what size paper to copy on.
                  This is what SCREWTAPE's post was about
                  iR5000/6000
                  COPIER>OPTION
                  MODEL-SZ
                  Use it to switch default ratios display and ADF original size detection by
                  site.
                  Settings 0: AB (6R5E), 1: INCH (5R4E), 2: A (3R3E), 3: AB/INCH (6R5E)
                  that setting displays paper tray sizes available / if u turn off Auto Detect for Glass or ADF>Read Above messages
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Teckat has given you direction that is base for your issue.
                    Harvey has a different issue. Sorry for the confusion.
                    • blu3sky
                      • Jul 2010
                      • 25
                      ok teckat, i'm just want to shut off auto detect for glass copies.
                      And your solutions was helping me
                      Thank you
                      For MODEL-SZ, I just want to share about the harvey issue
                      • blu3sky
                        • Jul 2010
                        • 25
                        ok no problem screwtape
                        • blu3sky
                          • Jul 2010
                          • 25
                          in my situation the value of size-det is 0, and the value of op-sz-dt is 0. But the sensor is on.
                          And I try to change the value of both to 1 then the sensor is off
                          • teckat
                            • 16083
                            when u change/ both to 0 - u need to turn off & back on printer for it to take effect/
                            what are u exactly trying to accomplish from glass copies/ that's disturbed you
                            • "Harvey Dent"
                              Enter service mode:
                              Worked like a charm.
                              Thks.
