IR 8500
  • TCS
    • Aug 2025
    [Misc] IR 8500
    When I'm making copies on lettersize paper that's coming out vertically, the 1st quarter of the page come out light, like if that section of the page have moisture in it. Similarly, right now I'm copying L/S papers horizontally. and I get it now and again. What could be the problem????
  • teckat
    • 16083
    let's get this straight
    what is your lead edge coming out of printer 8.5" or 11"
    • SCREWTAPE
      East Coast Imaging
      • 3396
      When I'm making copies on lettersize paper that's coming out vertically, the 1st quarter of the page come out light, like if that section of the page have moisture in it. What could be the problem????
      Where are you making copies from... The glass?? Or are these prints??
      Are you a tech or a user?
      Worst case. You might wanna start thinking about replacing the transfer separation corona assy and or your primary corona assy.
      But let's start with the basics
      • Canuck
        Tech Specialist
        • 1713
        step 1:re-wire corona assemblies....probably transfer wire is toast
        • molsonreddog
          • Oct 2010
          • 11
          Try removing pre transfer and make some prints from service mode. see if problem goes away.
          • teckat
            • 16083
            TCS/ BEEN MISSING FOR A OVER A WEEK
            • SCREWTAPE
              East Coast Imaging
              • 3396
              What a waste of a thread.
              • TCS
                Believe it or not, today the copier started to copy without that problem but I'm not sure if permanent. I was getting another problem now. When I made copies, it seemed in some areas the toner didn't fuse properly. The toner on the page was somewhat "roughish" and it would smear slightly. I took out the fuser unit and cleaned it up to an extent. I noticed where the web touched the upper roller was dirty. I think this happens when the web doesn't move, so I replaced it with a new one and by some miracle i wasn't getting the partial fading. Is there any relation with the fixing unit and the fading? I'll be getting a new transfer separator corona assembly to replace the old one. So the question now is, what's causing the "roughness" of the print?
                I'm a "user", I own and operate a copycenter, a one man show if you will.
                • TCS
                  how do you make prints from service mode????????????
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Bad fusing can cause toner to smear because its not fusing to the paper properly by the fixing assy. Bad bushings,old bearing can cause issues like yours.
                    *2&* >Copier>test>Type-(5)>Ok would be a good selection for test print.
                    (Type PG5 is a halftone test print.)
                    Thanks for posting back.
