I know this machine is ancient but, is still have a few out in the field. I have had this problem before and replaced the sep/trans unit(sometimes fixes it), hvt connector between composite and sep/trans, composite power supply and dc controller. Anyone else know another cause? This problem sometimes only happens on 2sided. It is happening now intermittantly on single sided copying. Thank you
NP6035 EO65 code
Tags: act, code, controller, copyi, copying, dc controller, hvt, intermittantly, power, power supply, roller, sound, supply, unit
andyleong
90% of the time it's the composite power supply.
Of the remaining 10%:
Shorted transfer/separation assembly
NP-6030 style transfer separation assembly installed (unit is shorter and makes poor contact)
Upper fixing roller bias shorted
Worn duplex rollers: (This may sound silly, but if the paper is delayed exiting the duplex tray the composite power supply is On before the paper arrives at the transfer roller, generating this code. I would scoff at this... if I hadn't seen it for myself.)If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
