ir2800 blank copies
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    ir2800 blank copies
    I have an ir2800 that just called in for intermittent blank copies, for the 2nd time. I was just there last Friday and replaced the transfer roller and drum. Any ideas?
  • collme
    Ricoh tech
    • 221
    been a few years since i worked on canon but my thoughts would be to rule out charge as this would give black copies not blank, if it was transfer then it would not be blank, just very faint unles the transfer roller was not racking up to the drum, this would cause jamming issues as well though. that only leaves dev unit really, if i remember right, it is a manually racked dev so maybe the cams on the racking shaft are broke or loose, this would stop the dev unit running upto the drum. my advise is to run sky shots and stop mid print, remove drum and see if there is an image on it, if there is then look at trnsfer racking upto the drum, if not then look at dev area.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      A bad laser could be a another reason for blank copies.
      • collme
        Ricoh tech
        • 221
        so so true screwtape, i did miss that one but surely an error would come up when bd signal is not detected
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Hi Dave,,, how about the not so obvious, of customer error, while using the doc feeder entry tray right side as a work surface to hold the documents that are yet to be scanned???? That will produce the blanks you speak of, you might want to demonstrate that to the enduser to show them the results of that bad habit, to see if that is what is happening...
            • 22999
            How about an intermittent scan lamp? Canons will make a few black copies, then turn off the charge and give you blanks. It will also store scan lamp intensity errors (E220) which you can check for. I also like the developing shift lever being broken. I've seen that one. =^..^=
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Blank copies have also been resolved by clearing DCON & RCON in service mode, re-input door specs and then re-boot machine. Print out spec sheet before clearing.
              Check connector J312 on the DC Controller for good contact, also cut the wire ties associated with J312
              And as I said before a bad laser can cause this type of issue. Symptoms. The copies start light and then end up as blank copies. The copy quality slowly degenerates and the copies end up as being blank when scanned or printed.
              Is this happening when they make copies from the 2800 or does it also do this when they print.
              If blank copies have not been rectified it has been found that replacing the DC Controller has resolved this problem.
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                Update - I was there today and finally observed the blank copies. No error, no hesitation, just spit out a completely blank sheet. I stopped a skyshot and there was no toner on the drum. Then after off/on switch the copies came out fine. The only error in history was an E191. It wasn't listed on the service map.
                They don't use it as a printer or fax. I don't know if this is important but about 2 months ago they had an E601 and I had to replace the HDD.
                MrFixit- that's eerie, I just had that exact problem in an ir2270 on Monday.
                Thanks for all the replies. I think I'm going to order a DC controller.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  E191 code indicates a communication error / fault has occurred between the DC Control PCB and the HVT unit on the Composite Power Supply.
                  • Check all of the connections for the DC Controller PCB and the Composite Power Supply.
                  • Make sure the wire harness between the DC Controller PCB and the Composite Power Supply is good by performing continuity checks (including crosschecks and checking for a pinched wire to ground for each wire) and visually inspecting it.
                  • Make sure the wall voltage is correct (neutral to ground should be less than 1 volt).
                  • Finally, try replacing the DC Controller PCB and / or the Composite Power Supply.
                  Also, in addition to the above timing, communication between the DC controller PCB and the composite power supply PCB was not successful from the end of a job to high-voltage output for the next job.
                  Thus a blank copy.
                  • yourownfree
                    • Dec 2007
                    • 474
                    How about this.... Cant prove it can you? want to know why? customer has a stack they want to copy. Using the doc feeder this is what happens. So they insert some in the tray and throw the rest of stack they will do later on the edge of tray because there is room to hold their stack while they copy the rest. Problem is when they do that it is pressing down on the other lever on the original document tray. yeah the same flag lever that is for legal or ledger.
                    Throws the machine off and kicks out a blank paper. trust me I had to problem solve this one before. It is that simple.
                    Mr fix it is right!
                    Last edited by yourownfree; 10-15-2010, 04:49 AM. Reason: found another with the same answer needed to give them credit for answering first.
                    • teckat
                      • 16083
                      Have u tried a DCON CLR
                      Remember to re-input door specs and then re-boot machine
                      • D_L_P
                        Self Employed
                        • Oct 2009
                        • 1196
                        My memory ain't what it used to be, I just remembered this is the one I got an E064 after replacing the HDD due to an E601.
                        This is one of those gravy accounts that only calls in once a year the last 4 years, has less than 400k and I've only ever had to put in drum/fixing film/tires. The drum is only 6 months old and less than 50k. 2 months ago when they had the E601, after I replaced the HDD and booted up I got an E064. I remember reseating the connectors and doing a DC-Con clear. When I went to re-input the values the ones for the HV-TR were way off. But after putting in the correct values it took off and ran fine.
                        They only remember the blank copies starting a "couple weeks ago", but customers aren't the most reliable source regarding time. I think I'll start with the DC-Controller and hold off on the laser for now. Thanks Screwtape for explaining the E191.
                        • SCREWTAPE
                          East Coast Imaging
                          • 3396
                          E64-xxxx is the high voltage transformer.(HVT)
                          This can also cause blank copies.
                            • 22999
                            I thought the high voltage functions were built into the composite power supply. Am I remembering correctly? =^..^=
                            • SCREWTAPE
                              East Coast Imaging
                              • 3396
                              I believe your right. The presence of a high-voltage error is communicated by the composite power supply PCB. The Main cause for the E64. The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
                              The service manual indicates the code is caused by a high voltage error. The output for primary charging, developing, or transfer has deviated from a specific voltage level. The two main areas to look at would be the composite power supply and DC controller.
                              E064 can be caused by the Developing bias value if its set incorrectly as well.
                              Check the setting of COPIER>ADJUST>DEVELOP>DE-DC in service mode. Compare this value with that of the service label. If the setting is found to be out of adjustment, set the value back to door specifications.
                              After making the adjustments, run some continuous copies to check for occurance of the code. Since this value is maintained by the DCON the same adjustment is required after replacement of the DC controller.
                              Check the steps below for troubleshooting.
                              1. Contact
                              Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
                              YES: Clean the contact, and set it once again.
                              2. Wiring
                              Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
                              a. DC controller PCB (J301) <-> composite power supply PCB (J136)
                              b. composite power supply PCB (J130-7) <-> primary charging roller contact
                              c. composite power supply PCB (J130-1) <-> developing assembly contact
                              d. composite power supply PCB (FT133) <-> transfer roller contact
                              NO: Correct the connection.
                              3. Composite power supply PCB, DC controller PCB
                              Try replacing the composite power supply PCB. Is the problem corrected?
                              YES: Yes.
                              NO: Replace the DC controller PCB.
