Black Spots
  • andalasgt
    • Oct 2010
    • 49
    [Misc] Black Spots
    Hi,
    what is caused the dirty drum (there are black spots on the surface of drum), as result there are black spots on the paper of copied.
    Thank's
  • ExXeroid
    • Jul 2010
    • 56
    Foreign matter on drum surface. Bad cleaning blade. Maybe if you give us a Model # we can help more.
    • andalasgt
      • Oct 2010
      • 49
      yes, there is toner dots on drum surface. How/why toner dots located on drum surface?
      • ExXeroid
        • Jul 2010
        • 56
        Does the machine use developer? Maybe developer and toner are clumping and sticking to the drum. What is the condition of the cleaning blade? Maybe you should change the drum and developer at the same time.
        • andalasgt
          • Oct 2010
          • 49
          the machine is canon ir5000.
          thank's. I would give you a model tomorrow.
          • badboys
            • Oct 2010
            • 69
            ..seems like the tungsten/corona wire (primary unit) is arching. Replace the wire frequently if you want the drum to last longer.I use Autosol paste to polish drum surface instead of rock stone brownish powder.(IR5000 drum lifespan = 5millions copies)
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              We call them "pepper spots"...
              Originally posted by andalasgt
              Hi,
              Thank's
              After reading to the bottom of the postings, I think I have figured out what you are describing, and Badboys has pointed you in the right direction. You either need to replace your primary charge corona, or rewire it, and clean the grid wires with clean water on a cloth. This should bring an end to your spots.
              This is easy enough to diagnose, if the tenth copy looks worse than the first,,, bingo, you have pepper spots!
                • 23009
                If the primary has been arcing there will be rows of tiny pinholes in the ASi drum coating. There is no fixing a drum like that. It's been a while since I ordered one of these drums but I seem to recall a price of $3K. If it has been arcing you'd better replace the primary too.
                Yep: Canon ImageRunner 5000I Drums
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Buff the drum. What kind of enviroment is this machine is in.
                  • andalasgt
                    • Oct 2010
                    • 49
                    thank's for replies. Here I give you a model test print of blank copy on a4.
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      What kind of print out is this?
                      Is this a test print from service mode?
                      A PG type 4 is a good one to use for this kind of issue.
                      Do you see the spots on the drum?
                      You can pull out the developer and check the drum for spots.
                      Keep your filters clean and free of dust, especially for the waste toner cleaning area of the AP kit.
                      • andalasgt
                        • Oct 2010
                        • 49
                        Yes, it was printed in service mode. I see the spots on drum. Drum was polished, but after about 250 copies it's coming back.
                        • teckat
                          • 16083
                          yes, it was printed in service mode. I see the spots on drum. Drum was polished, but after about 250 copies it's coming back.
                          change the filters/ check duct seals/
                          clean fan duct of dirty filters.
                          check primary post or replace primary unit
