iPRC7000VP E020-0281
Re: iPRC7000VP E020-0281
The Machine works great i become this error on startup, i see in a old sm that is a fan 3, but this mashine dont have this fan fm323.
The software on the maschine is recently updated, but is it every time the same code on start up.
He works well when i reset the err and dcon.
Have any some ideas?Comment
Don't see any sub codes for e822-1603 on this series.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
in the new manual i dont see this error only in the old manual,
in manual is the the error yode with y603, in the new i cant find the error code...
i look here at the site most of answer is that the possible answer is in manual rev 0 110410 but i cant find the manual..Comment
take a look at rotation of the cooling fans
do a monotonous check of fans in I/O mode**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Remember, in this series
When this product is powered OFF it will take approxiately 10 seconds for the 24v Power Supply to discharge to 0v.
If the Main Power Switch is quickly turned ON before enough voltage has been discharged from any of the e8xx-xxxx Error Codes they may be falsely detected.
Have seen keyops flip power switch off/on back and fourth in frustration.
Instruct the operator to wait at least 10 seconds after shutdown before turning the Main Power Switch "On".**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
did u check in ALARM CODES ??
can u isolate the deck> unplug it--then power off--on printer to check
DC controller PCB
1-2_________________u may need to replace assembly --may have a short or grounding issue
do u have dedicated outlets for this printer ???
e822 has no clear offer in service mode CLEAR>ERR ???
When a following error occurs, after taking appropriate action (remedy), be sure to turn ON the power, and then select the following to execute ERR: COPIER > FUNCTION
> CLEAR > ERR. The error is cleared by turning OFF and then ON the power after ERR execution.
E000, E001, E002, E003, E004, E013, E717, E719
For errors other than those described above, the error is cleared by turning OFF and then ON the power after taking appropriate action (remedy).
-When turning ON the power, be sure to turn ON the power in the following order: pickup/delivery accessories -> Main Body: Otherwise the pickup/delivery accessories are
not recognized
are u doing DCon clear to get printer up ????--or is printer down ????
post your picture of that code ----see example
EXAMPLE PIC
code.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
