Image quality problem - Adv. C7065
+ More Options
Posts
  • vidarb
    • Mar 2010
    • 25
    Hello.
    I have a quality problem on a Adv. C7065.
    Looking for some advice
    Magenta and cyan seems to drop on the top of prints, look at the image (scan1.jpg).
    Is it the developer already? The machine has only done about 220k and the developer is supposed to last 500k.
    And also just to confirm
    Look at the top left of scan 2 - is this the primary charger failing like i suspect?
    Even a broken clock is right twice a day.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Check the cyan developer and the primary transfer in the ITB for starters.
    • Fer
      • Nov 2009
      • 267
      I assume the Cyan developer is failing indeed. The black copy is made out of CMYK buildup i think? Maybe the result of the Cyan developer also. Remove the drum and inspect the developer rol.
      Maybe a broken stirring shaft?
      Is that pre-modified ITB mottled print?
      • nick55
        • Jun 2010
        • 51
        Originally posted by vidarb
        Hello.
        jus a quick analysis: get a good fresh paper first before doing any trouble shooting. if copy quality remains even w/ fresh paper, then start trouble shooting
        • Fer
          • Nov 2009
          • 267
          Oh come on, paper?
          Do u happen u work for HP or Xerox helpdesk?
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5006
            Service bulletin for your problem.irac9000-033.pdf
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Originally posted by zoraldinho
              Service bulletin for your problem.[ATTACH]6810[/ATTACH]
              Sure looks to me that you nailed it with that tech bulletin!
              • SCREWTAPE
                East Coast Imaging
                • 3396
                That's it.
                Nice find.
                • teckat
                  • 16083
                  Canon Europa :>)
                  • vidarb
                    • Mar 2010
                    • 25
                    Haha nice one - thank you, will try this new lever pin
