how to fix wait................ in iRb/w series
<Control Program Area>
- Control Program 1 (interval 2)1) The machine checks and initializes the various hardware on the main controller PCB.
2) If the previous shut-down sequence was not performed normally, the machine recovers the system files
as needed. (In this case, the start-up time tends to be longer than usual.)
3) The machine initializes the various program modules.
- Control Program 2 (interval 3)1) The machine initializes the various software modules, and checks the configuration of the printer/indicate E732/E733.
reader.
2) If the printer/reader is found to be normal, the machine ends the start-up sequence; otherwise, it will
Where does it stop?
Check one by one these parts and find which is wrong.You cannot repair the copier without changing parts at least just for test."Who loves the roses,must also bear thumbs"Comment
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Any accessories attached, finisher.
Check the reader cables.
Where any e-code noted in the past 3 months?
So it stops at the 2nd & 3rd interval which checks the configuration of the printer/reader.
You have past the 1st interval which runs a self diagnostic program. The program checks image memory(ram) and the HDD. Once that's done the software is loaded to the memory, in this case it seems like memory or the HDD is not the problem. BUT, you never know.
For the hell of it try the defrag 1&9.Comment
just share my experience...
several weeks ago I have problem "wait..." with ir7200...
it was on sequence 2...
after I change ethernet card, it was OK...
I was also having problem on sequence 3... I found that scanner connection not connect properly....Comment
stopbanks
