how to fix wait................ in iRb/w series
    • 16083
    Originally posted by davidj7
    screwtape : the progress bar reaches the end and then stops. like in the figure at the end of section 3.
    Have u reseated the DIMMS and the Boot on the Main controller
    • tinnyjay
      • Oct 2009
      • 663
      Originally posted by SCREWTAPE
      <Control Program Area>
      - Control Program 1 (interval 2)
      1) The machine checks and initializes the various hardware on the main controller PCB.
      2) If the previous shut-down sequence was not performed normally, the machine recovers the system files
      as needed. (In this case, the start-up time tends to be longer than usual.)
      3) The machine initializes the various program modules.
      - Control Program 2 (interval 3)
      1) The machine initializes the various software modules, and checks the configuration of the printer/
      reader.
      2) If the printer/reader is found to be normal, the machine ends the start-up sequence; otherwise, it will
      indicate E732/E733.
      Where does it stop?
      I think you must check fuser,dimms,power supply(Standard Rules).
      Check one by one these parts and find which is wrong.You cannot repair the copier without changing parts at least just for test.
      "Who loves the roses,must also bear thumbs"
      • davidj7
        • 1107
        [QUOTE=teckat;176387]Have u reseated the DIMMS and the Boot on the Main controller[/QUO
        yes i have .
          • 16083
          #19
          [QUOTE=davidj7;176423]
          yes i have .
          Just because u tried this HDD in another printer, does not mean the partitions are in agreement /
          I would format HDD- RE LOAD FIRMWARE
          • SCREWTAPE
            East Coast Imaging
            • 3396
            #20
            Any accessories attached, finisher.
            Check the reader cables.
            Where any e-code noted in the past 3 months?
            So it stops at the 2nd & 3rd interval which checks the configuration of the printer/reader.
            You have past the 1st interval which runs a self diagnostic program. The program checks image memory(ram) and the HDD. Once that's done the software is loaded to the memory, in this case it seems like memory or the HDD is not the problem. BUT, you never know.
            For the hell of it try the defrag 1&9.
            • madu132
              • Dec 2008
              • 65
              #21
              just share my experience...
              several weeks ago I have problem "wait..." with ir7200...
              it was on sequence 2...
              after I change ethernet card, it was OK...
              I was also having problem on sequence 3... I found that scanner connection not connect properly....
              • stopbanks
                #22
                Re:
                I also want to get the solutions, hope you will explore more your ideas...
                • waffu22
                  • Jun 2009
                  • 95
                  #23
                  How about the R-CON board? Have you tried to replaced?
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    #24
                    Of cousre he can try. I wouldn't focus on it. If there was a E733 then yea I would try replacing RCON.
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      #25
                      SPAM
                        • 16083
                        #26
                        Hello Jerk ! u have been REPORTED / post your spam links elsewhere
                        • davidj7
                          • 1107
                          #27
                          guys thanks for all the inputs i am keeping a boot rom and a few ram modules . Hope that will solve my issues in future
                            • 16083
                            #28
                            KOOL~~~~~~~~~~~~~~~~~~~:}
