7095 image shifting front to rear when duplexing
  • apump
    • Mar 2009
    • 160
    when running duplex letter the backside image is shifting towards the rear. sometimes it stays right on. I have another 7095 right next to it doing about the samething. the shifting varies up to an 1/8 of an inch. thanks....
  • Fer
    • Nov 2009
    • 267
    Does it have a sensor in the duplex path to measure the shifting of the paper?
    • apump
      • Mar 2009
      • 160
      no just a sensor in the middle of the path (duplex)
      • SCREWTAPE
        East Coast Imaging
        • 3396
        I believe that was on he 5000 series.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          <Duplexing Transport Unit>
          Make following adjustments under,
          COPIER > ADJUST > FEED-ADJ > ADJ-REFE
          Use this to adjust the horizontal registration for re-pickup (2nd side of 2-sided print).
          Increase the value if the image is displaced to the front. Range: -100 to 100_
          (unit: 01 mm)
          1) Make the following selections in service mode:
          so that the image margin on the 2nd
          side will be as indicated.
          - If the margin is too large, decrease the setting
          of ADJ-REFE (a change of 10 will decrease
          the margin by 1 mm).
          - If the margin is too small, increase the setting
          of ADJ-REFE (a change of 10 will increase the
          margin by 1 mm).
