Setting up Scan to a file - network destication
  • kouliscon
    • Jul 2025
    [CQ] Setting up Scan to a file - network destication
    Hello All
    Can somebody tell me how to setup the Canon ir1022 scan utility for my network.
    I tried to do it by my seld but i cannot.
    Just to inform you i have a domain and the computer which i want to save the file is on that domain.
    The printer is using fix IP.
    thx in advance.
  • doktor
    • 214
    Network scan only i models other USB
    • kouliscon
      Model ir1022i
      My modeil is IR1022i so it can scan and save it to network... i just dont know how... anybody can help?
      also email...
      • doktor
        • 214
        iR Toolbox for iR1018/1022 series
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          also email...
          You can use the send function.Install favorites buttons in additional functions.
          • kouliscon
            Hello
            My idea is to have the ir1022 only connected by ethernet cable and all the users to scan documents and to save them to the network, as well as to scan and send email to a specific email account. I just need help on setting this two things....
            thx in advance.
            • zoraldinho
              • Mar 2008
              • 5007
              Hello
              thx in advance.
              No problem dude.
              add. func.>address book set>favorites buttons>
              1. name
              2. host name
              3.file path
              4.login name
              5.password
              File name is shared folder with all rights on your disc or server.
              • kouliscon
                can you give me some examples?
                1) which protocol i use? FTP or SMB? if FTP means that i must have an FTP server running?
                2) host name must be like \\nameofserver ? or nameofserver
                3)file path is L:\IT\Scanned Documents ?
                4) login name is a user of the domain since i use donaim? domainame\user
                thx
                • zoraldinho
                  • Mar 2008
                  • 5007
                  thx
                  use SMB settings.
                  1.name(Kouliscon)
                  2.host name (kouliscon-pc)
                  3.file path(scan-"create share folder with this name on desktop)
                  4.user name(kouliscon"username for windows log on)
                  5.password(for windows log on).
                  use RUI.Its faster.
                  • kouliscon
                    Hello
                    I tried yesterday with the settings which you mentioned above but with no success.
                    Just to remind you that i have an Active Directory and the location which i want to save the scan files is part of that active directory.
                    So to the favourites button i choose:
                    1) File as SMB
                    2) host name ALUNE , which is the name of the computer where i want to save the files
                    3) file path is Scanned Documents , From the windows explorer i can see the location mentioned with \\alune\Scanned Documents
                    The location is shared with permission to everyone at the network and, security to everyone Full rights
                    4) as user name i have used a domain admin and a local user both with no success.
                    Do i need to have a user name since the location is shared with permission to everyone?
                    Thx in advance
                    • zoraldinho
                      • Mar 2008
                      • 5007
                      Hello
                      1) File as SMB
                      Thx in advance
                      Where is the location of the shared folder?
                      • kouliscon
                        at a computer which is part of the Active Directory called ALUNE and the shared folder is called Scanned Documents
                        thx
                        • zoraldinho
                          • Mar 2008
                          • 5007
                          thx
                          Check if you see folder from another computer.
                          Check permissions for folder.
                          Check firewall settings.
                          Try to create a folder on disc D:
                          Switch and router can be problem too.
                          • danilee2
                            If you have an AD with user Authentication then a valid username and password would be needed to access folder.
                            • kouliscon
                              Hello
                              - I can see the folder from the another computer by typing to the windows explorer \\alune\Scanned documents
                              - folder permission are full rights to everyone
                              - No firewall settings on this computer
                              - this computer has no D:
                              - i tried both SMB and FTP and both are to FTP i tried with activedirectoy\administrator and password and still didnt work
                              any other ideas?
