IR 550 jams at fuser rollers - simple cure?
  • Merv
    • 63
    Yeah, if I knew where and what that was?
    • Merv
      • 63
      IT'S WORKING AGAIN!!!
      Thanks for all the ideas and the guidance. I had the whole damn thing dismantled, looking for what everyone was describing, then put it all back together and it started working again. Hmmmmm.
      Only thing I can figure is a connection might have been left off during an earlier tray feed roller repair. I took off the circuit board on the back left side , the one that slides forward and lifts out. There is a single connection at the top, three at the lower left and one at the lower right. When looking around, after I removed that board, I saw the lower right one hanging loose and didn't remember taking it off this time. Maybe just alztimers, cause the machine printed a few thousand booklets since I had that off during the earlier repair.
      But I figured I'd just screw the thing back together and try it.
      Viola, I have just printed off a hundred booklets with no trouble.
      Me happy guy now!
        • 16083
        probably the Paper Pick-up Pcb
        good work, pays to back tract sometimes~~~~~~~~~~~~~~~~~~
        • kingpd@businessprints.net
          • 921
          #19
          Glad you got everything working...sounds like you had a ghost living in the copier.
          I did want to add this comment though b/c I experienced it. Sometimes when that series sits and isn't used for a long time the fuser and other rollers can get flat spots and it screws up the timing and causes jams. Something to keep in mind if any further problems persist.
          • Brian8506
            • 1664
            #20
            It also sounds like the web wasn't advancing when you referred to the lubricator film. The assembly on front of the fuser has a series of gears and one way bearings that advance the web. I've had gears crack and the web doesn't advance so keep an eye on that.
            • Merv
              • 63
              #21
              Well I just finished my thousand copy 8 page booklet. It felt like I was on top of the world. Cleaned the office (garage) and got all the spare parts and paper/toner organized. Was thinking, with my two spare copiers and this web forum, I might be able to stay in business.
              Then I come back to my 'puter and see this gold trophy!
              and these other comments.
              Damn, this might work after all!
              Thanks.
              AND yes I have consumed at least six since the last post.
              And to Black Cat - here is my Boy Rhythm's cat Chauncey
              He wasn't lickn' his chops when we took this. Seems we have similar tastes.
              Thanks everyone!
                • 921
                #22
                my kitty
                Pic of my kitty Rachel Lynn...and my wonderful editing skills.
                  • 23002
                  #23
                  If you don't mind, Merv, I'll use Chauncy as my avatar when I tire of this fellow.
                  kingpd, If you got got a better shot of Rachel Lynn, I'll use her too.
                  I don't want to damp your enthusiasm too much, Merv, but your jamming problem has probably just taken a short vacation, and will be back. For future reference, for the 010B jams:
                  1) The heat roller collars are behind that keyed gear in your photo
                  2) The bed fan is located in the pull out section in the center, beneath the black rubber belts.
                  3) The fixing motor is the one in your photo. There's a new style motor available.
                  4) and to tell if you've got flat spots on the pressure roller, hand rotate the fuser with the pressure on. If you've got flat spots you'll be able to feel the difference in difficulty when turning. Generally it will improve, but not go away entirely.
                  Congratulations. =^..^=
                    • 921
                    #24
                    My dad has the HD camera right now but I'll get some when he's done with it.
                    Sorry Merv, I forgot to post how to tell for flat spots. Thanks blackcat.
