Canon NP6317 shadows
  • shomyx
    • 36
    Hi! I have very strange problem with this np 6317.
    I change OPC kit, fixing roller, fixing roller bushings, pressure roller, oil roller, clean everything, set fixing roller pressure with C13 procedure, set heater temperature C9 on 190 Celsius (cant set more but in SM says up to 230) and still I have shadows on copies. What, where, how???? I try with other Drum unit ( but when forced work with open front doors I cant see shadows on copies when passing on redelivery belt so i think that problems are in fixing unit but where) have no idea? please help!!!!!!
  • shomyx
    • 36
    Well I think that I found where is problem! I clean toner unit from old toner , and put new one, and all my problems ( I hope ) are gone!!! possibly moisture in toner, old toner or replacement toner ( maybe I never found out)...
    • Herrmann
      • Jan 2006
      • 792
      You went in the wrong direction with your fusing temperature, set it to 160-165 degrees celsius
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • petra
        Edge Shadows
        Hello,
        I have a problem with my old np6317. The drum roller is dirty at the edges and the copies are out with both shadows. I attach an image
        I have cleaned the rollers of the toner and drum but in the next copy, the shadows on the copy and the dirty in the drum droller is here again.
        Can anyone help me?
        Thanks in advance
        PD: Sorry for my english.
        • montana
          • Aug 2008
          • 392
          Originally posted by petra
          Hello,
          Can anyone help me?
          Thanks in advance
          hi...if you working on A4 paper size change the orientation to A4R and see if the same problem still on..if doesn't replace the drum and cleaning blade..or the entire drum unit
          i hope this help
          regards
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            hello l have lot of work in this model of canon np6317 ...last day l repaired two copiers canon np6317 ...so firstly we should be use the original toner ..or other same bast ..like KATUN ...other something ..because this model is very old ..most model of np6317 and np1550..6220... have bad toner unity ...l think her time is over ...some np6317 have 256369 in her counter ...so we must be found the new toner unity ...second l agree our tech Montana you should be check the best with A4R ..it have difference in her developing surface ....but ..it have any relation by the fusion section ...the shadows problems in developing section ...good luck ..and we wait for any other problems ..
            BEST TECHNICIAN . NICE PEOPLE .
            • shomyx
              • 36
              For using KATUN toner I must say NO ! for that model wery bad toner . I have wery bad expiriance with that toner for this model ( a lot of black dots, shadowing text,after making cca 1500-2000 copies you have layer of toner on fixing roller what is wery problematic,etc...) dont use that toner- I stoped. If you not shure where shadows start use one trick- open front cover, put screwdriver in slot with switch, turn on make copy and just observe paper from beginig to end of copy proces, but in this case probably is OPC and cleanig blade for OPC.
              • copys
                • Jan 2011
                • 7
                Edge shadows
                This is my first post, so hello all.
                Right the edge shadows as shown in the picture attached by Petra are down to worn drum unit.
                The shadows on the 6317 are usually down to toner issue in the dev unit, if all other service work is done ie, clean optics, drum filter glass etc...
                replace and test, should be fine.
                I hope this helps
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  Welcome aboard!
                  • Kyo fan
                    • Dec 2013
                    • 368
                    Re: Canon NP6317 shadows
                    Hi everyone.
                    I decided to ask here, rather than opening a new thread. I came across one of these oldies and could use some help, since I'm not a Canon tech. I've had a vertical void on copies, so I cleaned optics, but it didn't help. Than i cleaned the drum corona, and the void was gone but copies became black as you can see here: scan.pdf
                    Any tip much appreciated.
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      Download Canon NP6317 Service Manual
                      The manual can be downloaded here. I would pay attention to chapter 10. The AE exposure
                      adjustment may get you where you want to be. Have not touched one of these clam shells
                      in a long time. Doesn't it have a density control in the front upper shell area? There used to
                      be a procedure when placing a new drum in the copier to get the bias set up. Cleaning the
                      charge corona may have put this out of wack,, worth investigating at any rate...
                      good luck
                      Mrfixit51
                      • Blizzoo
                        • Aug 2013
                        • 608
                        You can adjust the height of corona wires on charge and transfer sections,there is one plastic screw at each end.
                        And make sure you clean the last mirrors located underneath scanner section covered by a black housing.
                          • 23009
                          Did you notice this was a 4 year old thread? He sure has patient customers if he hasn't fixed it by now. =^..^=
                          • Blizzoo
                            • Aug 2013
                            • 608
                            Kyo Fan resume it
