I want to print cards on 8.5x11 paper that I would then cut, but before cutting them I would want to print individual ID codes on each card on the sheet. Can I print the page once to print the card design, and then run it through the printer again to print the ID codes on the same side (on areas that would have been left blank for this purpose)? Would that cause any problems with the fuser or anywhere else that there would be already fused toner in addition to "fresh" toner?
