canon ir 6000 reset unit 1 or reset unit 2
  • tariq65
    • Jun 2010
    • 84
    i an\m facing the problem in canon ir-6000 showing the massage reset unit 1 not make copy and red error light is blinking any body help me thank you .
  • SCREWTAPE
    East Coast Imaging
    • 3396
    The message Reset Unit 1 appears after the imageRUNNER boots up. This message can be caused when the imageRUNNER is unable to see the Fixing / Feeding Frame assembly. You should check the connectors for the Fixing / Feeding Frame and also the wiring between the connectors on the rear frame and the DC Controller. Sometimes the pins can become damaged or paper can get lodged inside of the connectors. If the connectors and the wiring are ok, the DC Controller may need to be replaced.
    You check this first.
    • teckat
      • 16083
      here are pics of what SCREWTAPE mentioned
      • bakaoni666
        • Mar 2010
        • 56
        Re: canon ir 6000 reset unit 1 or reset unit 2
        Sorry, I know it was an old post. But I still having trouble with it.
        Already check the connector, replace DC. Check Wiring, switch behind the handle.
        Still Reset Unit 1.
        Help me. 2 machine with this problem.
        • teckat
          • 16083
          Still Reset Unit 1.
          bottom line =
          u have a connection issue somewhere /or pinched wiring
          • bakaoni666
            • Mar 2010
            • 56
            Originally posted by teckat
            bottom line =
            Still looking, haven't found it..
            i hope i can find it today.
            Thanks Mr. Teckat
            • Austec
              Thanks Mr. Teckat
              Another confirmation here of listening to what teckat and Screwtape have said.
              This issue is almost always with a dodgy connector on the back of the fixing/feeder frame assembly.
              You can sometimes find removing the screws from the connector assembly at the rear of the fuser (right side connector looking at pic 2 in teckats photos) and packing it out with a couple of washers behind it before screwing back in place. This will make the connector fit more securely into the rear connector in the back of the machine. Do this if the problem is a bit intermittent rather than a constant indication.
              But whatever you find it will be poor wiring or connector between the fixing/feeder frame unit & the DC Controller. I've never had to replace the DC Cont to fix it yet.
              • copier tech
                • 8172
                Had this exact fault a few weeks ago. It turned out to be the small micro switch that detects the unit 1 handle is in the home position, simply bend the switch arm so it makes better contact or replace the switch.
                • bakaoni666
                  • Mar 2010
                  • 56
                  This is the first thing i did to make sure that switch is fine.
                  • Canuck
                    Tech Specialist
                    • 1713
                    You metered the switch? For continuity? Is there voltage at the switch? Have changed a few switches on these
                    • pramod
                      • Jul 2010
                      • 21
                      Have You checked horizontal registration motor in duplex assembly , because i have faced same problem there was hair crack in gear , replace motor or gear if you have. during boot time it should be at home position .
                      • bakaoni666
                        • Mar 2010
                        • 56
                        I Found it.
                        It was sub thermistor. Broken wires inthe connector.
                        Thanks for all replies.
